Turbocharger VSR Balancing information-
11-22-2014, 05:40 PM | #1 |
Rep 1,571
All,
It has came to our attention that there is some confusion in the arts of turbocharger balancing methods so we felt we'd take a moment to share our viewpoint on VSR balancing. We will not be discussing intricate details in the arts of proper VSR CHRA balancing, but wanted to give more of a high level overview of what it entails. Being concerned about providing customers the best possible quality in each and every turbocharger we took delivery of a new VSR balancing machine this past summer and have been very pleased with this machine to say the least. We all know that performance is great but what makes it even better is reliability. The bottom line is that consumers need turbochargers they can count on, one that has been bench tested to perform, and it needs to be done prior to shipping. This could save countless amounts of headaches and costs down the road. For those who may not know VSR stands for Vibration Sorting Rig. This is an expensive and delicate piece of equipment that gives visibility of a CHRA's performance under conditions they are subjected to when bolted to an engine. During bench testing the final assembled CHRA is bolted to a fixture and is injected with pressurized/heated oil and then a large supply of air is applied to propel the rotor through the entire operating RPM range that the unit will be subjected to in application (ie. 0-170k RPM). The entire RPM range is plotted on a graph along with a vibration intensity measurement at each point during acceleration of the rotor, and calculations are performed to help the operator determine where the rotor components can be lightened by very minute grinding techniques to lessen the mechanical vibration. This essentially is a way to determine whether a turbocharger is assembled correctly and allows the VSR operator to have ultimate control over the balance of the turbo cartridge assembly. As one can imagine, "vibrations" in mechanical components suggest that the device is imperfect and subject to larger wear in shorter amounts of time. Large amounts of vibrations mean poor performance, slow spool, oil consumption, audible noise, and at times a quick failure. A smooth operating unit that does not vibrate means exceptional lifespan, quick spool, low oil consumption, and superb performance. It is also worth mentioning that no amount of "robust" hardware can compensate for a poorly balanced center section. VSR's also indicate how well each CHRA is balanced by comparing the performance to a predefined OEM threshold. OEM thresholds are typically very high which can be acceptable for non high performance, but can lead to short turbocharger life if or when they are pushed harder than what they were intended. Also keep in mind that even IF a cartridge was VSR'd, it doesn't mean that it was done proficiently. Ideally each CHRA will be at balanced to what we refer to as "the balance floor", "flatlined", or at least very close to it. The report shows the performance and illustrates to what caliber the CHRA was precisely balanced. They can not always be absolute perfection and it should not be expected, unfortunately, but turbocharger manufacturers should be diligent in achieving as close to perfection in each unit as possible. Beware of manufacturers who do not have the cutting edge technology employed, as ultimately the product could suffer in reliability especially when pushed to the products outer limits. Some manufacturers maintain that they utilize the technology but they do not. CHRA performance and analysis reports should be provided to confirm. As always many things can cause a turbocharger to fail, sometimes outside of their control… but this is an absolute safe way to ensure the product is built to exceptional standards. Below is a sample of a VSR report for visual reference. Thanks, Rob PS- Would like to take a moment also to give a big thank you to Jesse @ Pure Turbo for helping us along and furthering the understanding in the art of VSR balancing! |
11-22-2014, 06:06 PM | #3 |
Rep 1,571
11-22-2014, 08:43 PM | #5 |
BimmerPost Supporting Vendor
24491
Rep 191,486
Useful info as usual Rob
11-22-2014, 09:40 PM | #6 |
Rep 385
Good stuff!
Since balancing is a bit of a cumbersome process, curious what sort of limitations you invoke on static versus group couples. To everyone else not well versed in balancing, the old way of doing this is lets say the compressor and the turbine both had a "high spot" or heaviest part of them at 12 o'clock. This means they'd both be exciting a 1-per-rev that would be quite high. In this case, however, the group couple would be zero. Now many people would just rotate one of the wheels 180* to "balance" them out. The static value of vibration, which is the chart like Rob posted, would read very very low, BUT, the group couple is now extremely high, with a very high phase angle. The turbo would measure well but would not last long. What's a group couple? Well, hard to write it, easy to understand, again, imagine two wheels on a shaft. Each of the wheels has a "heavy spot" 180* out from each other. Under rotation, they're going to try to bend the shaft. This plays hell with turbine engines, turbos, you name it. Actually, turbos are a lot more sensitive to this than turbine engines but I digress... The phase angle is just the angle between the two wheels' heavy spot. Rule of thumb is the smaller the phase angle, the better off you are. I know the rules of thumb for turbine engines and I know what Garrett strives for as well. So put it all together, you want to component balance everything (meaning balance them by themselves), then assemble them such that the group couple is within tolerance, THEN remove material/etc to get static within reason. If you just get static good and ignore everything else, I'll bet you a ham sandwhich and a grape soda that your turbos will have short, unhappy lives no matter how cool your graph looks. Cool info Rob, nice to see this getting posted for the further education of consumers. High group couple won't show up in a simple vib trace. It's calculated. I'm sure Rob has ways of dealing with this. I know what Garrett does and Honeywell, since I've done this operation many times for turbine engines -same same.
2007 E90, 6MT, VRSF 7" FMIC, RR DP's, Vargas Stage 2+ (19t unclipped), CP-e Charge Pipe/Tial BOV, BMS DCI, Fuel-it! Stg 2 LPFP, E66, 118k+ miles Brentuned
11-22-2014, 11:34 PM | #7 |
Rep 1,571
Great post. Agree on most everything. But the chart is not static, it's a dynamic representation of the entire group of components (each of which is individually balanced prior to strategic grouping/assembling). In short the VSR will see (and plot) imbalance of each plane and show them as out of phase as they appear dynamically, if they exist, and the operator then has the ability to correct one plane (or in some cases both planes at their discretion).
With this machine the operator can achieve what one can not come close to with the typical industry balancing standards, which many shops still utilize and consider acceptable. While VSR'ing, the operator can see that improvement not only make the graph more appealing visually- but there are very distinctive improvements as well. Improvements such as duration cycle of testing is dramatically improved (ie. Spools faster), audible sound of the rotor acceleration is much more pleasant, and finally of course the unit is making very low amounts of mechanical vibration. Thanks, Rob |
11-22-2014, 11:50 PM | #8 |
Rep 385
Glorious. That should make a significant contribution towards people being able to boost the piss out of things and not trash turbos.
11-23-2014, 09:57 AM | #9 |
Rep 1,571
Thanks sirs!
100% concurrence. |
11-24-2014, 12:10 AM | #10 |
Mad Linux Guru On The Loose
1130
Rep 5,404
All fine and dandy, but how did you end up determining 1.5 and 0.5 for OEM and Hi-Perf thresholds respectively? Where do these numbers come from? So far they look like they've either been arbitrarily selected or "cherry picked"...
11-24-2014, 04:01 AM | #11 | |
Rep 1,571
Of course the smaller the rotor assembly, the "tighter" the OEM threshold, as smaller rotor assemblies are known to spin much faster and being much lighter tend to inherently induce much less of vibrations overall. Typically the smallest of the turbos have an OEM upper threshold set at .5 grams. This information along with the combined VSR experience of us and others (ie. and VSR'ing other known new Hi-Po turbos), we well know what is is good and what is not. Quite frankly we even go much better than the .5 grams, on these turbos we are typically dynamically averaging between .1-.2grams as we take much time with them to ensure they are be best that they can be. This is the result of taking any amount of time necessary to achieve great results, it is not always easy to get them. As stated prior even if some do VSR balance it doesn't mean they are achieving good numbers, but the supplied reports should give you an idea of how diligent the manufacture is to obtain the best possible results. Also high speed balancing may still not be enough, you really want to see dynamic balancing (i.e. balanced through the entire RPM range). This thread is just to help provide some insight and information on VSR balancing, as we know it is something that is not talked about much or understood by many. Rob Last edited by Rob@RBTurbo; 11-24-2014 at 04:08 AM.. |
11-24-2014, 06:53 AM | #13 |
1130
Rep 5,404
Rob,
Thant makes more sense now. Thanks for the explanation.
11-24-2014, 08:59 AM | #14 | |
Rep 1,571
No problem and you are welcome. |
11-24-2014, 08:48 PM | #16 | |
Rep 1,093
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
11-24-2014, 09:19 PM | #17 | ||
Rep 1,084
11-24-2014, 09:29 PM | #18 | |
Rep 1,093
11-24-2014, 10:22 PM | #19 | |
Rep 1,571
You are welcome bud.
11-25-2014, 12:24 AM | #20 | |
1339
Rep 1,701
Drives: Slot Machines.. Keep Taking $
11-25-2014, 09:34 AM | #22 |
Guest
Rep n/a
Drives:
Neither is road force balancing, but 99% of the people actually using those machines daily don't have a clue about: what they do, how they do it, or what they're actually capable of. Doesn't mean that you, as a consumer, can't learn more about the process in order to understand what to look for when looking for a shop to do quality work.
