went from jb4 g5iso to cobb stg2+ aggressive st
11-23-2014, 03:24 AM | #1 |
Rep 271
went from jb4 g5iso to cobb stg2+ aggressive st.
ive been using jb4 for 2years for my 335i e92 2007 AT. and i decided to try another tune which is from Wedge performance. so i sold my jb4 g5iso meth kit +fsb and got the cobb v2. waited a week for my cobb. when i got the cobb today i decided to load the cobb ots stg2+ aggressive st to give it a try to compare with jb4 map2 while i wait for my wedge flash. and so after ive installed the cobb stge2+ aggressive st. OMG the throttle is much more improved and very powerful!! powerful than map2 is guarantee.. i use ron97 petrol 100% all the time.what makes me happy is the gear change. never in my life thought n54 could shift fast! turns out to be jb4 is not good at gear changes., slow i must say. its a very noticable difference. im very happy with cobb tune itself ! MORE TO COME! IM WAITING FOR THE SUPERFAST MAP FROM WEDGE TOMORROW! IT WILL BE FASTER THAN MY PREVIOUS MAP3 50ADD WHEN I WAS JB4 BACK THEN. BUT IVE SOLD MY METH KIT AND FSB AS I DONT NEED IT WHEN IM USING WEDGE FLASH AND COBB ALONE! ROOAAAARRR!! WILL KEEP POSTING FOR REVIEW!!
_______________________________________\\\ BMW 335I E92 2007 RHD 6AT,HYBRID TURBOS,BMS ADAPTER W/ 3.5BAR TMAP,VTT INLETS,JB4 G5ISO W/ MHD FLASH,AEM METH KIT W/ FSB,BMS DCI,ER CHARGEPIPE & TIAL BOV,VRSF C@TLESS DPS,FMIC,BMS OCC,BMS CABIN FILTER,MUFFLER CUSTOM BULLET,97RON PUMP GAS |
11-23-2014, 01:16 PM | #2 | |
Rep 271
E90 - N54 2007 Alpine White FBO :
VRSF CP w/ Tial BOV,VRSF 7 inch FMIC, VRSF Catless DP's, Hexon RR600, Cobb V3, VMR V710 Gunmetal 19x8.5 and 19x9.5, SteveAZ stage 2 bucket |
11-23-2014, 01:31 PM | #3 |
DisplacementReplacement
440
Rep 1,131
My take on this is the JB4 is a great product and has great results. I also had it for over two years and it performed well although I never liked how my transmission shifted with the JB4, but the power was there. I just recently switched to Cobb, I used to run it on my Subie's but wanted to read up and wait for ATR to catch up. I believe the community has learned, I believe Cobb has given us access to enough tables to tune effectively and so here we go. My initial thoughts on my initial two weeks of map revisions done by me is, adjustability is great, results are great. I don't see a reason at this point to go back to the piggy. By the way, the transmission shift issue is gone with the Cobb.
11-23-2014, 01:44 PM | #4 |
BimmerPost Supporting Vendor
24486
Rep 191,471
Off the shelf Jb4 offers more power than Cobb.
But Cobb is definitely smoother ( also keep in mind that the G5 ISO JB4 is a big improvement in terms of power delivery) Good luck OP with you custom map from Wedge,they do a great job
11-23-2014, 03:38 PM | #6 | |
Rep 271
11-23-2014, 07:10 PM | #8 |
Boost
1355
Rep 3,697
Drives: 135i M-Sport
You should really check out some of the more technical boards (rhymes with shmeamer shmoost) or n54 tech to understand what your car is doing with a jb4 vs a cobb flash. Did you ever try jb4 stacked with a backend BB flash?
Any logs to compare the two? Glad you like the new flash
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
11-23-2014, 07:48 PM | #9 |
1339
Rep 1,701
Drives: Slot Machines.. Keep Taking $
The calculated torque output has a direct impact on how the transmission responds. The back end flash uses a low load request and to compensate, they increase the torque divisor which increase the torque output calculation. Unfortunately, in my testing using the divisor to increase torque output has shown to have an adverse effect on timing. The piggyback logging is also incomplete with regard to tuning. A lot of the parameters needed are not available yet and they are working on adding a few more which will make it better.
11-23-2014, 08:31 PM | #10 |
440
Rep 1,131
11-24-2014, 01:37 PM | #11 | |
Rep 256
11-24-2014, 01:39 PM | #12 |
Rep 256
11-24-2014, 01:54 PM | #13 |
Rep 2,387
I just went exactly the opposite way, from Cobb Stage 2+ to JB4 G5 Iso. Both are good products and each have their strong points. I went to JB4 in order to have an integrated meth solution, now learning about all that and debugging hardware issues (slightly sticky waste gates).
I really like the gauge hijacking and in-car map/settings switching, etc. I waited to go to JB4 until they had individual cyl ign data logging capability, which IMHO is very important with things like meth and bigger turbos. So far so good. Hope to go bigger turbo(s) next year, we'll see how it works out. I have kept the Cobb so far as I may eventually want to try the back-end pump flash, and do not want to mess with the headaches of the various other "free" flash options. Yet. |
11-24-2014, 02:52 PM | #15 |
184
Rep 1,702
Drives: Audi TTRS, 335is
It's a far greater difference than that depending on what map you are running, ambient conditions, etc. Early backend flashes basically copied Cobb load targets which are higher and the results were less than stellar in regards to shifting with my car. Intermittent DCT slipping would occur with shifting. I can only speak for the DCT, but I have seen a big improvement in shifting with a flash only tune. Faster, sharper, crisper all of the time, not just some of the time. I spent a lot of time customizing my own backend flash to improve shifting and I felt like I made some considerable improvements; however, the inability to log actual load made it nearly impossible to get perfect. I believe Terry is working on adding the ability to log actual load and if he does, that should lead to some improvements in shifting when customizing the backend flash.
11-24-2014, 03:23 PM | #17 |
Rep 4,392
11-24-2014, 03:41 PM | #18 | |
Rep 256
The JB4 does not vary reported load by more than like 0.5psi. The back end flashes are another story, but those aren't JB4. Don't confuse the functionality of the two. If you display DME Target and ECU PSI you'll see. JB4 will keep the ECU blind to the actual load if it goes beyond the target load in the map. This may be the point of confusion here, however if you flash a map with proper load targets, you won't have this problem. If you're not running meth, or don't care about gauge hijacking and the ability to control boost and other features from the steering wheel, then you don't need the JB4. If you want to use it for those features, all you need is a proper map with load targets in the range of what you're actually running. However, that won't help move cobb units Last edited by nyt; 11-24-2014 at 03:51 PM.. |
11-24-2014, 03:52 PM | #20 |
3442
Rep 79,211
11-24-2014, 03:57 PM | #21 | |
184
Rep 1,702
The problem is the load targets in the OTS backend flash aren't suitable for every application. I had mine dialed in about as good as I can get them and sometimes the shifting was still hit or miss. It would be much easier to determine proper load targets if actual load was logged instead of trying to estimate load based off PSI. As you know load isn't fixed for a certain psi. It varies based on ambient conditions. Last edited by musc; 11-24-2014 at 04:05 PM.. |
11-24-2014, 04:03 PM | #22 |
Rep 256
