Annoying Hesitation/shudder on Acceleration, HELP!!
11-25-2014, 06:52 PM | #1 |
Rep 188
Hello all, this has been a pita issue for me, I believe this has started to happen after the jb4 was installed, in any map on light acceleration up to 4000 rpm Iam a getting a heavy surge (the car is shuttering/oscillating) its hell of annoying. If you floor it then its pretty smooth no oscillation. I have done a ton of research but couldn't come up with a definite answer. Also I have no fault codes stored. Anyone had same issue? Need some guidance here, thanks to all!
2008 335XI//JB4 G5 ISO//AFE STG2 INTAKE//M6 18"//BLACKED OUT TAILS//BLACKED OUT TRIM//
F10 550xi/Carbon Black/M-Sport/ |
11-26-2014, 11:51 AM | #3 |
Rep 289
Mines doing the same but only recently now that it's cold if I let it warm up for 20 minutes it won't do it. I know I should get carbon blasted and injectors soon. It is pretty annoying tho
11-26-2014, 12:01 PM | #4 |
Rep 1,403
It could be multiple things bro, however, in my direct experience with this in the past I replaced the plugs and coil packs and it solved the problem. It will get worse if that's the case trust me I've been at reduced power on I-95 south.. not cool.. There are many ways to check plugs and coil packs before you go out and buy some (not too cheap..) I suggest you do this before you purchase.. how many miles are on your vehicle and when was the last time these were replaced?
Edit: Also read the codes at autozone if it says misfire anything more than likely plugs & coil packs.. your check engine light will not necessarily be illuminated either.. |
11-29-2014, 12:28 PM | #5 |
Rep 188
SO far I have replaced all plugs, vacum lines, turbos,
Iam starting to think it could be just normal operation of jb4? Its pretty dreadful for a tune to be this jerky
11-29-2014, 01:40 PM | #6 |
Rep 1,544
Post some logs.
I had the same issue once with my ECU tune. It was caused by poor WGDC control and I remedied it by adjusting my D Factor and D Factor multiplier to smooth out the boost curve. |
11-29-2014, 09:43 PM | #7 |
Rep 188
how is that done? thanks
11-29-2014, 11:59 PM | #10 |
184
Rep 1,702
Drives: Audi TTRS, 335is
Get a log of it and send it to Terry. Lots of people have had boost oscillation at part throttle with the JB4 including myself. Up to 20% throttle adjusting menu 10 and 12 can help. I never had much luck fixing it. It's one of the reasons I wanted to try a flash only tune. No oscillation since going to a flash only.
11-30-2014, 06:59 PM | #11 | |
Rep 188
yea I spoke to Terry, I may be going with a flash, which one do you have?
