jb3 or jb+
12-01-2014, 02:13 AM | #1 |
Rep 83
jb3 or jb+
So im currently looking for a little more power and i saw jb+ going in the 100 dollar range i have found both available jb3 and jb+ which one is a better desicion to go with i am all stock except for bms dci and ER charge pipe 2007 n54 what would be a better choice?
12-01-2014, 08:36 AM | #3 | |
Rep 633
12-01-2014, 10:39 AM | #5 |
184
Rep 1,702
Drives: Audi TTRS, 335is
If you are just looking at those two because of the $100 price point then I would go with JB3. Just keep in mind that the JB3 is no longer supported by BMS if a problem were to arise. As others mentioned, JB4 G5 is the best/newest option but its around $500.
The JB+ features a faster install and does not require you to touch the ECU. The JB3 is a more robust system including map switching, direct boost solenoid control, throttle position mapping, and many other additional features that allow it to produce a lot more power. On average the JB+ gives 40-50hp to the wheels, while the JB3 gives 70-80hp to the wheels, on an otherwise stock car. |
12-01-2014, 10:54 AM | #6 | |
Joint Chiefs of Staff
4927
Rep 116,037
JB4 is your best bet. Mike |
12-01-2014, 11:24 AM | #9 |
Rep 83
12-01-2014, 11:26 AM | #10 |
3442
Rep 79,211
It uses outdated technology. The fueling capacity and ignition timing is not nearly as good as the JB4 from a safety standpoint. The JB4 has better control of fuel, ignition and boost. The JB4 also comes with conservative maps out of the gate compared to JB3. The Jb4 is able to monitor all 6 cylinders now too.
The JB3 just rides the knock sensors and fueling is typically very lean in the low-mid range. I'd sooner to tell you to save up but I do know guys that are still using JB3 to this day since 2008. |
12-01-2014, 11:42 AM | #11 |
Rep 1,314
Drives: 2021 X3 M40i, 2018 Mustang GT
12-01-2014, 12:03 PM | #12 |
Rep 179
Drives: Chevrolegs
Save your money and pick up the JB4 when you can! Or keep your eyes peeled for a used one!
12-01-2014, 12:25 PM | #13 |
Rep 2,872
Don't forget to factor in the cost for replacing the spark plugs if they have more than about 30-40k on them. When tuned they should be changed every 25k to avoid misfires, etc.
Get the new JB4 G5 so you'll be able to update it, and have some support incase you need help from Terry or Russell@BMS |
12-01-2014, 12:38 PM | #14 | |
Rep 1,040
The JB4 has to be one of the best bang for the buck tunes out there in the Euro car scene. A lot cheaper than the tunes for the Audi's and VW's that don't yield anywhere near that gain. If $100 is your limit for spending on a BMW 335i, I think you're driving the wrong car. Especially since you will be needing some fresh spark plugs to compliment that new tune, even if you go with the very outdated JB3.
2009 335i M Sport coupe, BSM with black/aluminum interior, 6MT, JB4 G5, MDH Backend Flash, Walbro 255 inline LPFP, VRSF Inlets, BMS 3" catless DP's, Borla Aggressive catback, ER FMIC, ER charge pipe, Tial BOV, BMS 2.3 gal Meth Kit, BMS Sport Oil Cooler Valve, Ported CDV, RB PCV, Cyba ram air scoops, Status Gruppe SRS coilovers, ECS trailing arms, Forgestar F14 SDC.
12-01-2014, 12:42 PM | #15 |
Rep 174
I have a jb+, it works fine. Makes a very noticeable difference over stock. I have no desire to drive the car without some kind of power adder. That being said, I am switching to a used cobb soon as I want to make good use of the e85 in my area.
12-01-2014, 01:00 PM | #16 |
Rep 83
I think im going with a jb+ for now only reason for sticking with 100 dollar range is because i just got new valave cover gasket sparks and doing oil change and bms dci so i need to save up for the jb4 next just wondering for the time being what would be a better choice.
12-01-2014, 01:27 PM | #17 |
Rep 219
For $100 budget get the $180 BT cable and load up a canned OFT tune. You'll want one when you go JB4 anyway. That should provide a real good bump in power for under $200.
12-01-2014, 05:38 PM | #20 |
Rep 83
so i actually found a really good deal on jb4 and just got it.. now after getting the usb cable what cable do i need to hook up to android? thanks everyone for the info
12-01-2014, 11:37 PM | #21 |
Rep 1,093
If you have to stay in the $100 range you should fork over another $100 and get a $200 BT cable and flash one of shiv's stage 0/1 XDFs using the free flash software (or can we still not say this although everybody who wants to know knows this by now?). Safer than all that, affordable, way more low end tq and probably better everything than a outdated jb3. If you ever decide to get a current jb4 you can still use what you have to "backend" flash the piggyback.
12-02-2014, 02:57 AM | #22 | ||
184
Rep 1,702
