Engine/Transmission Mount Upgrade, WHO HAS IT?
12-04-2014, 01:12 PM | #1 |
Rep 3,251
At 40k miles and after half of dozen of track days, I am thinking of changing up the stock motor mounts and perhaps the transmission mounts as well. They are not leaking or anything yet, but I been noticing some some rub on the subframe from the downpipes even though they have almost 1/2" of clearance...
Choices are: - 335is driver side mount (supposedly stiffer than standard mounts), funny thing is that 1M still uses the old standard p/n instead of the IS p/n... So not sure how much of an upgrade can they be... - AKG 75D Bolt through mounts (http://www.akgmotorsport.com/catalog...Trans%20Mounts) - PTF/Motiv Solid engine mounts So the questions are who has them done. Any noticeable improvement, how about daily street driving? How big of increase in NVH are they? Transmission mounts are plenty of to choose from. I probably would go with the UUC black with mount cage (http://www.ecstuning.com/ES2702573/)
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
12-04-2014, 01:42 PM | #4 |
Guest
Rep n/a
Drives:
I've read in a few other threads where someone brought up the point that it would probably be necessary to go with an aftermarket harmonic balancer when going with solid mounts. Not really sure where to start with that, but it certainly is an interesting point to consider.
Thoughts on that PTF? Also, are your mounts still being made? Didn't see them on the website. |
12-04-2014, 02:15 PM | #5 |
Rep 3,251
Well, I reached out to Jake@Motiv a while ago about their mounts. He mentioned it might be rough for DD... If someone has a cold start video from the interior of their car, it will probably clear things up a bit. N54 and N52 are some of the smoothest engines out there, so it might not be so bad, I hope... The AKG ones is a bolt through design, so it is essentially a solid mount...
If not, I might just go with the is mount and call it a day. It is just sucks that there aren't that many options out there to choose from, unlike the M3.
12-04-2014, 03:05 PM | #6 |
Rep 6,478
Solid motor mounts are gunna rattle...It is what it is.
I've run poly Rogue mounts for the transmission for at least a year, and it didn't introduce anything annoying. Obviously, a different ballgame than solid mounts though.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
12-04-2014, 04:12 PM | #7 | |
Rep 1,910
I have had the re trans mounts for about a year and a half now, no increase in nvh.
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost. Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold) |
12-04-2014, 08:30 PM | #8 |
Rep 303
I have the PTF/Motiv solid motor and trans mounts and barely noticed anything until I put the twin disc clutch in...now it's rattle city, but a lot of it might clear back up with different trans fluid. Although, with the OEM flywheel I had a nasty vibration after the mounts under 1000rpms. Not sure what to make of it since it went away after the twin disc install.
12-04-2014, 09:53 PM | #9 | |
Rep 3,251
12-05-2014, 01:32 PM | #10 | ||
Rep 1,643
2007 E92 335i MT
12-05-2014, 05:36 PM | #11 |
Rep 3,339
Don't go with solid mounts. Need convincing? Come over and go for a ride in my E30 track car w/ solid mounts. You wouldn't even consider them for a DD.
12-05-2014, 05:48 PM | #12 |
Rep 169
I have the solid MOTIV motor mounts and UUC semi sold trans mounts. Lots of NVH, but I found out when doing the twin disk that my OE clutch was exploded, so I'm attributing some of the NVH to that. In fact... very similar to "The Convert" and his description.
You can hear a lot more engine noise with the solid mount, but it really isn't bad. I have straight pipes and all of the M3 bushings, 335is guibo, etc. so what I experience is probably not the norm. I'll find out in about an hour how the twin disk differs from OE setup.
IG @pobudz | '08 e92 335i - MOTIV 750 w/ PI & AEMMHD tuned, tial bov, ER cp, ADE "800HP" fmic, Corsa 3.5" catback, m3 suspension bits (F&R sway, F&R control arms), rogue toe arms, MOTIV motor mounts, UUC trans mounts and RTD shifter. H&R sports and Koni's, 17x9/17x10.5 Forgestar F14 w/ Mickeys. Quaife 3.08 LSD, M3 subframe and diff bushings. MOTIV Twin disk. Fuel-IT Stage 3+.
12-05-2014, 07:30 PM | #13 | ||
Rep 303
12-06-2014, 09:50 AM | #14 | |
Rep 169
12-07-2014, 02:53 AM | #15 |
Rep 3,251
N54 is stupidly smooth in comparison to all other engines I have driven over the years. Before the exhaust, I often find myself forgetting to shift up just because the lack of vibration feedback from the engine (always been driving it in M mode since the first day). So it is good to hear that MT guys are pretty happy with the solid mounts.
Still worrying about the nvh at idling for an AT, since the engine is constantly under load unles you shift into N or P, which would be a pain to drive in the city. Someone gotta have these on an AT... |
