AFE vs Dinan vs GruppeM
12-12-2014, 12:51 AM | #1 |
Rep 199
I know this subject has been beaten to death, but I wanted to know if there are some threads or charts some where that have actual comparisons between these intakes because as far as I've read any of these intakes are better than a DCI from BMS or Injen.
Edit: Eliminated a few intakes and added new ones, due to some feedback and more research. Last edited by Fishayyy; 12-14-2014 at 03:08 PM.. |
12-12-2014, 09:04 AM | #2 |
Rep 1,321
Drives: Truck in snow, coupe in summer
I did this same search and ended up going the DCI route from vrsf. Car sounds better and noticed some increased throttle response. Imo the stock set up is pretty solid so dci for sound like cbe. Dp's for power!
12-12-2014, 11:02 AM | #3 |
Rep 2,872
It really depends how much you care about looks IMO. If you're willing to spend that kind of money on an intake than that's fine, but they all show the same numbers performance wise, including the DCI. Maybe slight IAT differences that's about it.
12-12-2014, 11:17 AM | #4 | |
ex deus machina
124
Rep 968
as far as intakes in general why do you need one? I theory the reason high flow filter are “high flow” is because they trade off some fine particle filiation which could be ok on a NA car but with turbos spinning at some outrageous speed the leading edge of the compressor can erode from the fine particles.
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK Gone: E92 335i N54 468rwtq |
12-12-2014, 12:18 PM | #5 |
Rep 303
ALL intake will perform the same for the most part. You will not notice gains from one over another. It all boils down to how you want it to look. Intakes are honestly a waste of money on this platform.
12-12-2014, 03:39 PM | #6 | |
Rep 199
12-12-2014, 03:44 PM | #7 | |
Rep 199
I'm just sick of seeing "BMS DCI FTW" and not seeing any dyno charts or statistics to prove that one is a better option than the other. Also BMW Performance does make an intake... http://www.bmwusa.com/Standard/Conte...akeSystem.aspx |
12-12-2014, 04:39 PM | #8 | |
ex deus machina
124
Rep 968
BMW does not make a performance intake for the N54 you should check yourself before trying to correct others...
12-12-2014, 05:03 PM | #9 | ||
Rep 303
12-12-2014, 05:21 PM | #10 |
3442
Rep 79,211
The consensus was the AFE Stage 2 Si Intake performed the best in real world conditions on the track and also on the dyno, according to BuraQ's reviews. (which at the time he was not a vendor, nor does he sell the product even today). I would say he is the most unbiased as he did his own testing on his dime for the greater good of his own car and to help others.
12-13-2014, 03:25 AM | #11 | |
Rep 2,808
12-13-2014, 06:29 AM | #12 |
Rep 865
Drives: BMW X3 35i, Porsche Macan S
I am very happy with my Dinan CAI. It is designed to supplement the stock air source with a second air source by the front vendor. I would be worried about potential hydro lock with the Stett design. Granted the Dinan is very expensive but it is the best CAI IMO. I never liked the idea of DCI's sucking in hot air.
I agree that the performance gains from any intake upgrade are very modest on this platform.
MOTIV 750 ST | MOTIV PI | 100% E85 | Fuel-it Stage 4 LPFP | MOTIV Boost Box + MHD Protune | Quaife | Öhlins | Brembo | Akrapovic
12-13-2014, 08:40 AM | #13 |
Rep 1,093
Best intake is single turbo and new BMS silicone filter.
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
12-13-2014, 01:37 PM | #14 | |
Rep 199
I was also pretty interested in the clutchmasters flywheel he reviewed, but now I'm a little skeptical... |
12-13-2014, 01:39 PM | #16 | |
Rep 199
12-13-2014, 01:40 PM | #17 |
Rep 1,093
Gains of 400-500whp is pretty good I would say it is the best. Search around lots of dyno's posted.
12-13-2014, 01:43 PM | #18 |
Rep 199
12-13-2014, 06:19 PM | #19 | ||
Rep 303
12-13-2014, 06:56 PM | #20 | |
Rep 199
As for clutch masters, is there anything wrong with the fX850 (the one that former_boosted_IS got)? Because I haven't seen many other people get it aside from him. Last edited by Fishayyy; 12-13-2014 at 07:02 PM.. |
12-13-2014, 08:28 PM | #21 | |
Rep 303
12-14-2014, 12:55 AM | #22 |
Rep 4,392
Best CAI for the N54 platform is the aFe Stage 2 Elite SI . I have tested up to 23 PSI and it supplies efficient air for the turbos. I am currently running 460+ whp and 554 wtq 21-19 PSI tappered and wgdc on an average stays below 70%
Here is my review on the intake broken down into chapters as I upgraded it http://www.e90post.com/forums/showpo...00&postcount=1 I went a bit further spend $15 more and sealed it for more testing. The cover does not need to be "perm" sealed just needs gasket to be made. My proof has been posted on another thread, I trapped 121-122 mph in the 1/4 mile FULL WEIGHT + me 260 lbs + half tank of gas, and I dont even have catless downpipes, only highflow catted downpipes. http://www.e90post.com/forums/showpo...00&postcount=1 Last edited by BQTuning; 12-14-2014 at 01:02 AM.. |
