12-13-2014, 02:41 AM | #1 |
Rep 100
Problem coding esys error c157
Hi, I'm trying to code my car with enet cable and esys + esys premium program with token generated, and gives me the following error
Used eSys (Includes E-Sys v.3.26.1 & E-Sys Launcher Premium 1.05 (w/ Builtin Token Generator) & Guides) and v.54.1_PSdZData_Lite. Used windows XP Professional. I am not able to encode to leave the error, is there any solution? A greeting and thanks in advance It is a bmw 1 series f21 Last edited by r0b3r; 12-13-2014 at 03:37 AM.. |
12-13-2014, 04:42 AM | #2 |
Rep 3,227
I think you will you find you haven't pointed Esys to your token.
From memory, go to the options settings in Esys, go to the token tab and make sure the path to your token is correct. Viola, I hope |
12-13-2014, 06:46 PM | #4 | |
Rep 41,181
Drives: 2018 Alpina B6 650ix GC
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
12-13-2014, 10:44 PM | #5 |
Rep 100
12-13-2014, 10:49 PM | #6 |
Rep 41,181
Well, you cannot launch E-Sys directly, as the E-Sys Launcher program manages E-Sys use of the .EST Token, so without it, E-Sys has no working Token solution. Contact TokenMaster for support with his E-Sys Launcher program:
http://www.bimmerfest.com/forums/pri...newpm&u=350398
emrah_060.00 |
12-14-2014, 06:51 PM | #8 |
Rep 41,181
01-08-2019, 02:40 PM | #9 | |
Rep 1
Hi my friend , I have same issue pls how you fix this ? Thank you! |
