Seat belt and airbag light after battery install
12-20-2014, 06:12 PM | #3 |
Rep 263
Drives: E46, E91, F21
Check if you dislodged your dislodged the small connector on your positive cable. The one that clamps directly to the positive terminal on the battery. There is a little connector that sometimes gets pulled off.
12-20-2014, 06:17 PM | #4 |
Rep 2,731
yea like someone said, the positive battery cable has a small explosive charge that fires when you are in an accident, to disconnect power. You probably didn't hook that small connector back up right.
12-20-2014, 07:10 PM | #6 |
Rep 263
Look at the connector on the top left corner of the battery in this pic and see if there is a loose connection at the red positive terminal block. You can see sheathed wires (Blue and Brown) going to it. ***NOTE***This is not my picture. I am just using for reference. Thanks
12-20-2014, 08:11 PM | #8 |
Rep 248
I check all the other connection and everything is secured. However, I do remember accidentally disconnecting the blue connecter on the top right corner by accident on the install though
12-20-2014, 08:18 PM | #10 |
Rep 263
Cool! Good to hear that that was it. It's a commonly disconnected item when replacing a battery, even at the deanship level. All you need to do now is clear the codes with a scan tool that is able to clear chassis codes.
12-22-2014, 08:19 PM | #12 |
Rep 263
06-28-2022, 03:35 AM | #14 |
Rep 1,662
sorry to revive this thread Abacus38
but i just changed my battery today and am also seeing the seatbelt tensor warning. Could you provide more detail as to which wire you found that was disconnected by accident? I'm trying to find it as well.. |
11-18-2022, 03:41 AM | #15 |
Rep 2
Drives: 2011 bmw 335xi sedan
I've recently had new ghassan n55 remanded n55 motor installed , new dme , new wire harness new boost solenoid new BMW valve cover and valvetronics motor new crank cam and both map sensors all by a so called performance shop that seriously robbed me of over 20,000$ and car still has an over boost problem throwing car into reduced engine power mode ????? cats dme has just been flashed by a tune shop with multiple pulls and revised after revised tunes , all vacuum lines and components replaced , boost solenoid replaced , coils and plugs replaced all with genuine BMW parts from BMW , cars upgrades include stage 2 upgraded twin scroll single power turbo , downpipe, charge pipe , intercooler , jb4 tuner , full exhaust , brand new n55 motor and wire harness , brand new dme from bmw brand new bmw battery and fuel injectors yet car still has over boost upon hard acceleration putting car immediately in reduced power mode ????????? PLEASE IM DESPERATE IVE SERIOUSLY SPENT OVER 20,000$ AND LAST 2 YEARS TO CURRENT IN SHOP TIME , 4 DIFFERENT SHOPS AND OVER BOOST ISSUE STILL NOT FIXED ?????BOUGHT CAR 2 YRS AGO AS IT WAS IN ENGINE REDUCED POWER MODE AND KID WHO SOLDS TO ME SAID THAT WAS FROM TUNE IT HAD ? NOT KNOWING A DAMN THING ABOUT TUNED CARS I BELIEVED SELLER THAN 2 WEEKS AFTER DRIVING CAR , CAR BLEW CYLINDER 6 ALL WHILE HAVING THIS OVER BOOST ISSUE THAT NOW AFTER LAST 2 YEARS , NEW ENGINE , NEW DME , NEW SENSORS , NEW EVERYTHING BUT SAME UOGRADED TURBO AND SAME JB4 TUNER IS HAVING THE SAME OVER BOOST PROBLEMS! PLEASE ANYONE HELP IM DESPERATE !
