Codes on jb4
12-27-2014, 03:30 PM | #1 |
Rep 302
Codes on jb4
So I put my jB4 in a little while ago. Once i got it all in I went to run the usb cable through the glove and realized the hole was behind everything i just stuffed into the ecu box so I said screw it and ill do it this winter while its garaged.
Anyways. I ripped out of a toll both the other day and my car decided it would lose most power and limp along. No engine malfunction or anything on the screen but it was the same as if that happened. Parked it and reset it back to 0 and it drove fine and then after put it back to 5 and it drove fine. Where can I get the code list or can can someone read this real quick for me and give me a little insight. Prob spark plugs but boost gauge is also acting like theres a leak. Any help would be great. |
12-27-2014, 08:57 PM | #2 |
Rep 2,872
http://www.n54tech.com/forums/showpo...35&postcount=5
http://www.n54tech.com/flash_files/N54_codes.pdf Read the codes then post them here if you can't find the answer on Google or searching the forum. |
