new bmw owner
12-28-2014, 11:58 PM | #1 |
Rep 12
new bmw owner
I bought a 2007 335i 4dr MT, first bmw. Its my daily driver, has 89k. PO gave me service records of spark plugs, coil packs, battery, and also a wastegate problem fixed, all not too long ago. There might be some other stuff, can't remember. Is there anything I should do as preventative maintenance? I don't plan on modding unless I am making it more reliable, e.g. adding an oil cooler or something.
12-29-2014, 09:21 PM | #4 |
Rep 12
It also had the turbos replaced, and it had a recall for the battery cable. I am worried about the whole PS pulley and subframe problem. I will probably try to take a look at that tomorrow. I might just replace the motor mounts to be safe.
12-30-2014, 03:32 AM | #5 |
Rep 755
Welcome to the forums, shine90! I would also recommend changing all the fluids (i.e., transmission, oil, brake) as part of your preventative maintenance. Did you get a pre-purchase inspection on the car before finalizing the purchase?
Car: 2007 e90 335i 6MT - sports, premium, cold weather, light, and smoker's package. Performance Mods: Cobb AP v3, ETS 7" FMIC, Injen DCI, Michelin PSS, CDV delete, rear spoiler, BMW PE w/ Magnaflow tips, PTF pro-tune, VRSF downpipes, ER chargepipe w/ Tial Q, APEX 18" EC-7 wheels, MP outlet/ inlet, MMP Stg. 3 turbos. Other mods: BMW cargo liner, 20% window tint, BMW alarm system, Weathertech floorliner, Lux E90 V6 bulbs, Philips X-treme Vision H7 bulbs, Blackvue DR650GW-2CH.
12-30-2014, 04:27 AM | #6 | |
Rep 755
You would need to physically check for the oil cooler on your car to know with 100% certainty. I have posted an image below that shows how you can check for the cooler. You can look in the passengers front wheel well. If you see the little grills there, this means you have the oil cooler, if not, then you don't have it. See photo:
12-30-2014, 05:29 AM | #7 |
Rep 2,189
Forgot to say if you have over 60k I'd replace belt, belt tensioner and idler pulleys.
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
