log review ltft maxed...help
01-06-2015, 06:04 PM | #1 |
Rep 56
currently running cobb ots stage2+fmic LT. car is fbo w/ vargas stage 2 turbos on pump gas. I've been getting codes ECU P0174 & P29E1 which are fuel system too lean bank 2 & fuel mixture control while highway cruising...
anyway heres a log from last night..3rd gear to 4th gear http://datazap.me/u/bimmerdave/3-4th?log=0&data=3-12-14 heres is a log of highway cruise.. http://datazap.me/u/bimmerdave/cruise?log=0&data=3-14 Last edited by BimmerDave89; 01-06-2015 at 06:13 PM.. |
01-06-2015, 06:31 PM | #2 |
Rep 2,872
I don't know much about COBB OTS maps, but if I was FBO w/ aftermarket turbos, i'd be getting a custom tune written for MY car to prevent these issues.
I'm sure Buraq/Ken from Wedge will be able to figure it out real quick, along with some other Cobb guru's. My .02 would be to have a tuner write flashes for your setup, instead of a generic map.
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
01-06-2015, 10:12 PM | #3 | |
Rep 56
thats why i posted the logs... |
01-06-2015, 10:39 PM | #5 |
Rep 654
I can't see those logs, are they private?
Second the one log I can see was uploaded December 2nd and leaves A LOT to be desired. It doesn't have any of your trims logged so I can't see those but what I can see is that post shift you were still WOT, requesting a load of 190 and had AFR's in the high 14's on pump gas. Your LTFT's maxing out is a really bad sign as that means your STFT are maxed out and were probably doing so regularly. You REALLY need to tune your car for the hardware you are running. Leaving it until spring is NOT recommended.
2008 E88--Fuel-It! Stage 4 LPFP & PI--PS2 turbos--JB4/MHD--FBO--662whp/604wtq
2011 E90--Fuel-It! S2BL LPFP and PI--PS2 Turbo--JB4/MHD--FBO--546whp/589wtq 2013 Mini JCW--Tune--DP--FMIC--a couple Fuel-It! goodies--265whp/320wtq 2013 F10--JB4/BM3 2015 F82--Fuel-It! Stage 3 LPFP & PI--PS2 Turbos-- JB4/BM3-FBO |
01-06-2015, 11:27 PM | #6 | |
Rep 56
01-07-2015, 12:08 AM | #8 |
Rep 56
stage 2+fmic aggressive LT on 93octane...i thought that too, i got really cheap gas a few weeks past, though it was from mobile...3.11/gal when other places were around 3.20/gal...haven't gone back there bc i started getting these codes with that tank...been using sunoco since and seem to take longer to see these codes show, usually show around 30 mins of highway driving cruising round 2k rpms
01-07-2015, 12:10 AM | #9 |
Rep 654
I still don't see a highway cruise log. Only the one in December and the 3/4 log in January.
Your scalar could definitely stand to be adjusted, that is fairly high. Not as familiar with the Procede but it may have been adjusting your "open loop" for your mods and fuel. Given it's colder now....your trims would increase as the air is more dense. Get a pro-tune....they will send you a base map for your mods and in the mean time you could just use that and have them adjust it if needed. When the weather is better they will work with you to dial everything in. If they don't agree to that...go with somebody else but I know most of the tuners will.
01-07-2015, 02:50 PM | #10 |
Rep 4,401
Drives: 2022 F97 X3M Comp LCI
bump the fuel scalar for both banks to around 1.1.
adjust accordingly and the codes should go away.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
01-07-2015, 04:37 PM | #11 | |
Rep 56
01-07-2015, 04:42 PM | #12 |
Rep 56
Ok I will give this a try thank you for your reply...I also failed to mention that when I was running procede I had a fuel flash from them to run a 50% e85 mixture...this before the oft came out..so I had to send the dme into them...they said I can run pump or mixture...just use procede to load proper map...SO hopefully this helps... thank you again!
