AE exhaust on E90 335i
01-07-2015, 07:47 PM | #1 |
Rep 537
I just installed my AE exhaust and everything went smooth. Except for this one clamp that will not go back in place. I assume the new exhaust piping is larger in diameter and now the bolt for this clamp is too short?
Can someone with an AE exhaust confirm if this clamp will fit or needs new longer bolt? The clamp towards the bottom of the pic. |
01-07-2015, 11:01 PM | #3 |
Rep 1,267
Guessing your talking about the clamp that holds to two pipes? Does the bolt not catch the threads cause it looks like it's fine on yours?
Have the same exhaust that clamp works just fine.
08 AW 6MT | MHD | Wavetrac LSD 3.46 | AE Quad | VRSF DP'S | VRSF 7" IC | DD Hood / Diffuser| Mtech Front / Rear| BMW Performance Splitters / Spoiler | Wheels 18lb 18x9 SQ | Hexon RR550 | TFT Inlets |
01-07-2015, 11:51 PM | #4 |
Rep 3,251
It should have come with a longer bolt. The stock bolt is too short for the now larger diameter pipes.
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
01-08-2015, 12:54 PM | #5 |
Rep 537
The clamp that holds the two pipes up, that is not a pic of my exhaust. I will have to try again and see if it will go back on. Then again, I installed this by myself so maybe with 2 people it will work.
01-08-2015, 01:33 PM | #6 |
Rep 1,264
you can always rethread that for a longer stronger bolt. just my experience i've had that snap on me.
2010|335i|LMB|E92|6MT|MSport|Logic7|335is Clutch|AE Performance|BMS|Walbro|VRSF 7"| 149.7mph NFZ AZ 1/2mi
1992|Pontiac Firebird|Mild 355ci|T56| -I will look on your treasures, gypsy. Is this understood?- |
01-08-2015, 03:18 PM | #7 |
Rep 380
I have a Vangaurd V2 exhaust and ran into the same problem.
Take the current OEM bolt to any hardware store and get the same thread pitch/diameter bolt that is longer. I would guess 90% of hardware stores will have it. EASY fix!!! |
01-12-2015, 12:56 AM | #8 | |
Lord Scrip
1823
Rep 3,018
Drives: 2011 M3 Coupe
01-12-2015, 03:49 PM | #9 | |
Rep 537
Do you guys here some kind of rattling when you first start the car when the engine is cold? It sounds like the heat shield under the body is rattling from the exhaust rumble? |
01-12-2015, 04:46 PM | #10 | |
3442
Rep 79,211
But if a heat shield is loose it's pretty easy to replicate, just start hitting the shields and see which one makes noise. |
01-12-2015, 05:55 PM | #11 |
Rep 537
Just had both turbos replaced in oct 2014. It doesnt sound like WG rattle.
01-14-2015, 09:07 AM | #12 | |
Rep 380
