Replacing turbos next week with a lot of documentation. Will post here when I'm done.
01-08-2015, 11:59 AM | #1 |
Rep 40
For any of those who have done this yourself, any tips and tricks to save time would be appreciated.
Also, if you guys have any requests for pictures, etc. during the swap, let me know. |
01-08-2015, 12:21 PM | #2 |
Rep 315
Drives: 2008 Deep Green 335xi 6MT
Subscribed. Also nice name. Reminds me of miley cyrus
01-08-2015, 12:29 PM | #3 | |
Rep 1,039
01-08-2015, 03:43 PM | #6 | |
ST
Rep 23
its a must. |
01-08-2015, 05:18 PM | #7 |
Rep 1,039
I have done 2 single turbo upgrades on the floor with jack stands in the past month. It can be done on the floor. It's not that bad. I can have the turbos out in about 4-5 hours. This way.
01-08-2015, 05:19 PM | #8 |
Rep 719
Get yourself a harbor freight engine support bar... Best 80 bucks I've spent at the freight.
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
01-09-2015, 07:12 AM | #10 |
Rep 40
This is how I am doing it as well. I have access to a lift, but would prefer to do this at my own pace.
01-09-2015, 07:13 AM | #11 |
Rep 40
01-11-2015, 04:33 AM | #13 |
Rep 308
The guys have already said it all. Tony Vargas encloses some advice for swapping out the turbos, as i don't have access to a lift i got Darren Wood to do the work. Drop the sub frame, check oil lines and replace if need be. Change oil and filter, and prime turbos (turn engine over to get oil into turbos without starting...i presume fuse is removed)
01-12-2015, 12:30 AM | #14 |
Lord Scrip
1823
Rep 3,018
Drives: 2011 M3 Coupe
Put the car on jack stands. Place a jack under the motors oil pan with a piece of 2X8 between pan and jack. Loosen booth motormount nuts. Jack motor up 1-2 inches. Remove passenger motor mount. Remove overflow tank and boost solenoids by the whole bracket. Boom, have at it now!
BE CAREFUL IF WORKING UNDER YOUR CAR!!!!! DO NOT CUT CORNERS ON SAFETY!
01-12-2015, 04:54 AM | #15 |
Rep 5
Love this thread and hopefully you're putting a lot of pics and info on here, cause I've bought RB turbos which I'm gonna put on within a month, so it's nice with a lot of good advice and how to do it easiest But is there really enough space to take off and mount the new turbos if you're only lifting up the engine 1-2 inches?
Are people also putting on a new waterpump now that the coolant is going off as well? I've also got a lift and engine support bar for getting the job done easiest |
01-12-2015, 03:44 PM | #16 |
DIYER
614
Rep 5,521
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
01-12-2015, 10:26 PM | #17 | |
Lord Scrip
1823
Rep 3,018
01-13-2015, 06:29 AM | #18 | |
Rep 5
01-13-2015, 08:21 AM | #19 |
DIYER
614
Rep 5,521
You're more than welcome
01-14-2015, 02:39 AM | #21 | |
Rep 126
