P0172 code, sputter at idle, cold start related
01-13-2015, 08:14 PM | #1 |
Rep 44
I keep throwing a p0172 code (bank 1 running rich) I can clear code but once I start the car after it has sat in the cold all day at work at first car runs fine but after about 30 seconds I start to feel a sputter at idle and I throw the same exact code over.. I've tried searching but can find a stright answer only mod I have are the oiled air filters, any idea as to what this can be? I was thinking maybe MAF need to be cleaned due to the oil from the filters... Help please car runs fine once I start driving I just want to fix the problem without replacing a bunch of parts
01-14-2015, 08:36 PM | #6 | |
Rep 719
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
01-14-2015, 08:47 PM | #7 |
Rep 44
01-14-2015, 09:05 PM | #8 |
Rep 44
Also I did do the sea foam treatment just to see if it cleared things up a bit, and when i did a cold start a few hours later things seemed to have cleared up, but I will only know for sure tomorrow mornkng once I get a true cold start.
01-15-2015, 06:01 PM | #9 |
Rep 719
Yes. I doubt seafoam fixed you car but it can't hurt.
01-17-2015, 05:07 AM | #10 |
Rep 44
Def cleaned some out, but didn't smoke as bad as I thought it would. But still didn't help, ses light is back on and I'm still pulling my hair, I will be checking g the Injectors next, anyone know how these can be tested without pulling the spark plugs?
01-17-2015, 07:33 PM | #11 |
Rep 719
The easiest way to test for a leaking injector is to pull the plugs... Takes like 30 minutes
04-15-2016, 09:52 AM | #14 |
Rep 178
i had the same problem, it only happened on a cold start in the morning from my car sitting over night, injector would leak and have a hard time starting and when it did it ran rough for a little then went away. changed injector and problem solved.. but yes pull the spark plug youll notice it right away
04-15-2016, 10:07 AM | #15 | |
Rep 3,560
Thanks for the feedback! |
