Best way to hit 16-17psi stable on jb4g5? problems with map5..
01-14-2015, 06:09 AM | #1 |
335
32
Rep 306
I'm currently FBO on pump fuel euron 98 (US 93). I hit 14.5 on map2 like it says but on map 5 most times it hits 12psi despite that weather is fairly cold and IT is like 80-85 most times. I rarelly get 16psi on map5 like once every 2 weeks.
What is the best way to hit a 16-17 psi stable? is it with a backendflash or by using map 6 or???
Too much mods to list.. |
01-14-2015, 06:29 AM | #2 |
Rep 1,497
Map 5 is a learning map.usually after you reset the fuel trims by 1 and 7,the first wot run in map 5 will be 16-17psi.if everything is okay car will keep that psi,if it's running lean or anything it will make adjustments which usually end up being lower boost mostly due to crappy fuel
01-14-2015, 07:40 AM | #3 |
Rep 2,872
Click into map 2, then back to map 5, then do 3 WOT pulls within a few minutes of each other. Drive around after that and see where you're at.
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
01-14-2015, 08:58 AM | #4 | ||
335
32
Rep 306
01-14-2015, 09:46 AM | #5 |
Rep 2,872
Which firmware are you on? Are you reading timing values of all 6 cylinders? I used to see 18.5 PSI on Ver. 27 but at Ver 28.3 I only saw 16PSI, the new 28.5 is supposed to correct that issue most people had, I can't confirm that since my clutch doesn't like that much boost anymore.
Try to get a log |
01-14-2015, 11:57 AM | #7 | |
Rep 633
01-14-2015, 11:57 AM | #8 |
184
Rep 1,702
Drives: Audi TTRS, 335is
The only way is to not use Map5. You can increase Map6 boost levels in small increments and log until you find a safe boost range. Fixed boost maps > learning/variable boost maps.
01-14-2015, 12:00 PM | #9 |
3442
Rep 79,211
If you find map 5 inconsistent then stay with Map 2.
Map 6 is for those who know and understanding tuning principals, I'm not against it but it's not for amateurs who just get boost hungry without understanding the pros and cons. At any rate, logs are important for all maps so start with that. |
01-15-2015, 11:15 AM | #11 |
3442
Rep 79,211
You may find more people looking at your logs if you post them to datazap.me.
JB4 logs are something like hieroglyphics to most of us. Thin lines, similar colors and weird scaling makes them hard to read. |
01-15-2015, 12:05 PM | #12 |
underground
67
Rep 333
Drives: alpine white 335 E92
Both logs say you are way under target. Boost leak maybe??
01-15-2015, 04:30 PM | #14 |
Rep 965
Drives: e92 m3
looks like a boost leak,pwm is shooting up
e92 m3 dct
gintani stage 2+ full ethanol custom pulley and meth kw clubsport,ap racing radical,volk te37sl,akrapovic rear,recaro profi xl,voltphreaks battery |
01-15-2015, 04:56 PM | #15 |
Rep 722
This looks like a pull from map 1 but its targeting 15 psi
Check all your piping from turbo out to throttle body and also check DV or BOV for possible leaks something is not right there.
11' m57 335d 165k Miles - JR 2, ATM Full Exhaust & Intake, Wagner FMIC, AAR Boost Pipe, AAR Swirl Delete, AAR EGR Delete
08' n54 135i FBO E85 - SOLD |
