01-18-2015, 08:59 AM | #1 |
Rep 5,580
Braking tip from Vic Elford
Have an ice storm here in Maryland and running summer tires. The description below from a driving handbook from Vic Elford, I thought, was excellent technique.
Even with anti-lock brakes, when braking on sheer ice, it may be helpful to pump the brake pedal. If not pumping then repeated applications at a rate you feel prudent. The theory being: the moments between having a rolling tire and locked under braking is the period when the tire is slowing with good road contact. If you can produce as many if those "slowing" periods between ROLLING and LOCKED then you can reduce speed quickly. Many times on ice there is such low friction between tire and road the ABS won't activate because it thinks the wheel is stationary. There are times when a locked-up wheel, will create a wedge of debris like gravel or even snow, and that wedge will slow the car. Sheer ice though, will probably not build up a wedge. Anyway, drive safe. |
01-18-2015, 09:40 AM | #2 |
***** noob
1381
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Pumping brakes are pre-abs
Slam on the brakes with abs and it pumps for you
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
01-18-2015, 10:05 AM | #3 | |
Rep 5,580
The premier benefit of ABS is you just about eliminate the chance of flat- spotting a tire on a dry road, and you bring in steering. However on ice - ABS may increase braking distance, ABS may not activate. You can watch video of ABS outfitted cars sliding into one another on ice, one reason being prolonged braking distance and sometimes that is due to an ABS system failing to identify that a car is moving. |
01-18-2015, 10:13 AM | #4 |
Mess Deck Commando
244
Rep 807
Our BMWs are equipped with DSC (Electronic Stability Control (ESC) mandatory in US as of 2012).
It provides: - correcting impending over-steering or under-steering; - stabilizing the car during sudden evasive maneuvers; - enhancing handling on gravel patches e.g. road shoulders; - and improving traction on slippery or icy roads. |
01-18-2015, 07:13 PM | #6 |
Rep 193
This is against everything I've ever seen, read, or heard about ABS over the last 20 years. You should never pump the brakes if you have ABS. That is, unless you can pump faster than the computer. In other words, I don't trust this fable. Sorry.
01-18-2015, 07:16 PM | #7 |
Rep 5,580
It's really the only time you should cadance brake ABS - in extreme ice situations.
01-18-2015, 07:31 PM | #8 |
***** noob
1381
Rep 10,479
Driven in New England weather for over 20 years and I can tell you pumping ABS will NOT work on icy or whatever the road condition is
Its the tires that slide on ice
2006 325xi (Sold)
01-18-2015, 10:08 PM | #9 |
Rep 2,529
Drives: 2011 328i Wagon
Possibly useful on older cars where there was no stability control system.
Modern ABS/Stability control are much smarter - the computer knows the car is moving, so even if you did manage to lock all four wheels on ice, it is not going to let them stay locked.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
01-19-2015, 06:56 AM | #10 |
Rep 1,066
Guys, I inadvertently tried this last night (ice in father in laws driveway after freezing rain, worst case scenario.) I can confirm that if there is no friction then the ABS does not activate at all. The car thinks it has stopped even in the case where I was doing a solid 5 mph. ABS works by detecting lockup as a differential between the wheels. If all wheels have zero grip, then it thinks you have stopped.
01-19-2015, 07:50 AM | #11 | |
Rep 46
SO you've never had that situation where you're only going 10~20 mph and trying to stop smoothly; yet ABS activates nearly putting you in an intersection? ABS is a pretty static system. If it detects locking it will activate? No if ands or buts about it. ~3pac3
2014 228i Sport-Line
Jet Black Exterior, Dakota Coral Red Seats, Premium Pkg, Technology Pkg, Lighting Pkg and Heated Seats! |
01-19-2015, 08:04 AM | #13 |
Rep 1,066
01-19-2015, 08:11 AM | #14 |
Rep 5,580
01-19-2015, 09:26 AM | #15 |
Rep 36
There is some merit to this advice which apply to very specific circumstances.
ABS systems will only be active after you achieve a certain speed, IF you slow down to a the point that ABS is not active then this technique helps. It MAY even activate the ABS system. The driveway situation described by tke743 illustrates this perfectly. One of the solutions to this problem is not to drive when the roads are covered in ice since traction is almost non-existent on icy roads even with winter tires (which I use) and even if you are the best driver in the world, but this is obviously not practical. The most workable solution is to use "studded winter tires" (metal studs if allowed and rubber studs if metal studs are illegal), if these are legal in your state. Here is a link to states and their laws on studded tires: http://drivinglaws.aaa.com/laws/studded-tires/ I hope this helps and everybody stay safe |
01-19-2015, 09:31 AM | #16 |
Rep 862
Drives: '19 M2 '21 X5
Our cars have accelerometers in them as part of DSC... They know when they aren't stopped.
I have had my car on ice (lake) and with full brake force the ABS is indeed working. Same is true of any modern vehicle that i have ever driven... |
01-19-2015, 11:28 AM | #17 | |
Rep 1,066
I'm everyone's friend, but I ran into this yesterday and limit was the only option. Especially when the limit is almost zero. This was an inch of smooth ice with new rainwater on top. Near zero traction and that was with snows.
This was worse then a dry ice surface on a lake. This was enter slow at 5 mph and even with limit braking attempts I slid over 100 feet. I've never hit anything like this before and it is probably a once in a lifetime issue, but it was illustrative of the discussion here. |
01-20-2015, 06:06 AM | #18 |
Rep 2
Just took the 2 day BMW driver's school... Regardless of road conditions, if you need to stop the car, give it full brakes and let ABS (and DSC) do it's thing, remembering to look to where you want the car to go and it will go there.
The worst thing you can do is pump ABS brakes. On the newer cars, ABS can brake individual wheels that are locking up and do so faster than a human. When you pump ABS brakes, you are disengaging braking on all 4 wheels regardless if they're locked up or not. Instructors also said if it's icy, stay home. Not even winter tires will help. Can confirm, almost put M235i in an intersection due to ice (ABS was engaged fully and entry speed was less than 20mph). Also got rear-ended when fully stopped on ice - another great reason to stay home when icy - you may be able to stop, but others may not. |
01-20-2015, 09:00 AM | #19 | |
Rep 438
I live in a *very* wintery climate where roads are constantly covered in snow pack and ice. I've never had my ABS think "I'm stopped". |
01-20-2015, 09:25 AM | #20 | |
Rep 862
I like you live in a very wintery climate. the concept of "not going out when its icy" doesn't work. Period. Should i sit in my house 8 months of the year? People need to learn how to drive and anticipate ice... |
01-20-2015, 03:40 PM | #21 | |
Rep 347
Rarely, if there is absolutely no grip to all four wheels and they lock, then the ABS system may not engage, as if the vehicle is stopped. The ABS senses no differential in rotation between wheels. Then pumping or threshold braking techniques may be needed. This might happen in "black ice" conditions where there is no warning. Otherwise, driving must be adjusted for the conditions. That includes choosing the right tires.
F22 * (N55 + 6MT) ÷ PSS = FUN
01-20-2015, 10:04 PM | #22 |
Rep 438
I would be very interested in reading this, so far the abs is working as expected.
I do wonder how speed affects the trigger |
