01-19-2015, 01:41 PM | #1 |
Rep 82
Combox retrofit
How do I retrofit my Combox Media PnP.... I looked into it last year and was told to get the "current car integration level". I cannot find this and my dealership will not help me. How do I get the software integration level and what combox do I need to get the album artwork, bluetooth radio, etc.
2011 535i Born date of May 27th 2010 C602066 |
01-19-2015, 03:16 PM | #2 |
Rep 413
You need to get one of the options: 6NH or 6NS to be retrofitted with a necessary hardware (according to VIN) connected with a specific harness and properly coded into your car's head unit (I believe it is CIC due to the pre-LCI year).
Please see a thread where we were helping another member to order the media stuff: http://f10.5post.com/forums/showthread.php?t=1075167 You will find the link to Ordering Guide and Pricing Guide in the post #9. Then for the 6NH/6NS full explanation refer to the post #13. Hope this helps. |
02-03-2015, 07:32 AM | #3 | |
Rep 9,097
You need followings; 1- Combox 2- Combox socket 3- Schematic of wiring from TCU / MULF2 to combox You car has TCU (for telematics) and MULF2 high (for 6FL / USB in the arm rest). Once you get the schematic, you will have to shift the wiring from TCU / MULF2 to combox socket. Change the VO of the car and code the car. You do not need to update the i-level. Good luck.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
12-19-2017, 03:19 AM | #4 |
Rep 1
Hey, guys!
Before starting my own thread I wanted to try my luck here, because I also want to retrofit a Combox into my 2010 January 535i, VIN C262409 My main goal is to be able to stream audio via bluetooth(at the moment I have only phone call possibility). I have a USB port and aux port in the middle console. An added bonus would be the possibility to have the car recognize Spotify as that is all I use. https://support.spotify.com/us/liste...mw-integration Now what I don't understand is which exact Combox model should I be looking for, as there are a lot of choices available (The car is from Germany) and if possible, more detailed necessary coding instructions. Thank you in advance! |
