I am just a man who wants all of you to look at my log. Anything wrong with that?
01-24-2015, 09:43 AM | #1 |
Rep 316
Only mods are Jb4 G5 ISO, VSFR catless downpipes, BMS E85 flash, K&N drop-in filter, and running an E50 blend.
I just made the jump over to the E85 flash last night, as the pump flash was pulling a TON of timing under load. I am no expert, but this looks pretty darn good to me. The surprising thing I see is that there are nearly zero fuel trims. Could you guys please weigh in? |
01-24-2015, 10:15 AM | #2 | |
Rep 2,872
01-24-2015, 10:29 AM | #4 |
Rep 2,872
Also, this thread has LOADS of info that I listed below. Look for the link "logging parameters & their meanings" also in there somewhere.
http://www.n54tech.com/forums/showthread.php?t=10605 |
01-24-2015, 11:13 AM | #5 | |
BimmerPost Supporting Vendor
1339
Rep 1,701
Drives: Slot Machines.. Keep Taking $
If your trims are at 0, reduce your scalar on both banks by 10% and see if you can get the trims to hold at 20 + or - 10. Not crazy about how he scales the trims, because they should be 0 + or - 34, but 0 to 50 works, just don't want them at 0. |
01-24-2015, 12:01 PM | #6 |
Rep 316
Here's the Datazap.
http://datazap.me/u/davyhay/first-bm...log=0&data=1-4 |
01-24-2015, 12:04 PM | #7 | |
Rep 316
01-24-2015, 03:39 PM | #9 |
Rep 316
http://datazap.me/u/davyhay/0-120-e6...11-13-14-15-19
Okay, I had some interesting issues on this run. I bumped up to E60 and put the Open Loop setting on 0, as instructed by V8Vait. This is a 0-120 run, and timing went to zero when I hit 4th gear, and then I had a misfire on cylinder 1, resulting in limp mode. |
01-24-2015, 08:37 PM | #10 |
1339
Rep 1,701
You would be a lot better off working with the guys over at N54 Tech as that's Terry's site and his guys would be able to help more than I can.
01-24-2015, 09:19 PM | #11 | |
Rep 2,872
Here OP: http://www.n54tech.com/forums/forumdisplay.php?f=35 It looks like the IAT is up around 170+ towards the end, so a bigger FMIC wouldn't hurt either.
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
