Need you input on this log!
01-30-2015, 02:52 AM | #1 |
Rep 2,799
Running the Cobb OTS E30 map for the first time, car feels great.
After reviewing the log, it looks like I'm getting a bit of throttle closure and some slight timing correction across all cylinders. It looks like it's taking place when I hit full boost. Is this just a boost overshoot and my wgdc needs to be adjusted? Or is there something else going on here? Thank you in advance for the help! http://www.datazap.me/u/dmacc/cobb-e...1&data=1-17-21
thanks to MGallop |
01-31-2015, 11:09 PM | #4 |
Rep 510
Think it's related to fueling, but I'm unsure. However, I have the same issue with the Cobb e30 OTS map. Logs look very similar to yours.
'2018 F87 M2 LCI | LBB | GC Camber Plates | Ohlins R&T 90/190N/mm | 18x10 et33 square 275/35 | MPe | Poly Transmission Mounts | Recaro Sportster CS
