03-02-2015, 08:49 AM | #2 | |
Rep 242
03-02-2015, 09:30 AM | #6 |
Rep 2,067
I don't like the auto start/stop function in my X1. It's a PITA.
One of the 1st things I do after starting the car is to hit the auto start/stop button (see below) to disable that function for the duration of my trip. When I get my new 2er ragtop later this month, I'm going to ask the dealership to code it such that the default is "disable auto start/stop".
2019 X2
03-02-2015, 09:37 AM | #7 | |
Rep 587
Drives: 2020 M2C
03-02-2015, 09:41 AM | #8 |
Rep 2,067
Yup, I already do that for most of my in-town driving, but when I get on the freeway and settle in at 130Kmph (generally the normal speed on our 100Kmph limit highways), I generally slip it into "D".
2019 X2
03-02-2015, 09:48 AM | #10 | |
Rep 2,067
I hope this has been changed for current model BMWs..
2019 X2
03-02-2015, 12:29 PM | #14 |
Rep 602
Same as above with mfourn. I have an early 2014, M235, and my preference has been shut off and it has stayed that way. It comes back on IF I would be in Eco mode...but as long as it its in comfort or sport...no problem.
03-02-2015, 12:45 PM | #15 |
Rep 470
ASS disable memory has been in place since MY2014 I believe. You should not need to code in order to get the ASS Off to stick when you turn on the car.
The only exception is that if you go into Eco Mode, it will enable ASS.
2015 M235i | AW | 6MT | Tech | Heated Seat | Parking Assist | Fabspeed DP & Muffler Delete | Apex PS7s
1999 MX5 NB | Emerald Mica | 5MT | Sport Edition | Kosei K5Rs | Heated Rear Glass ig: @bee2ven |
03-02-2015, 01:07 PM | #16 |
Rep 3,332
Modern turbos have been designed with different cooling designs than turbos from the 90's/00's when turbo timers were more relevant.
Improved cooling designs means it is not nearly as important to let the turbo cool off for an extended period of time as it was with older turbos. If you have been driving the car hard, then yes cooling down is always suggested but as mentioned auto-stop start is permanently disabled with 1 button press and the car will sort out when to automatically enable/disable ASS.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
03-02-2015, 02:46 PM | #17 |
Rep 395
Oh, OK. I guess mine does the same thing. My bad!
03-03-2015, 05:49 AM | #18 |
Rep 289
Yep what he said! I remember all the Associates saying that no matter what it always goes back to default after you turn the car off and go back into to drive it again but that's not the case, only defaults back when you select to drive in Eco-Pro Mode as the car thinks you want to drive economically which makes sense hence why it switches it back on to give you the best MPG possible. But it's good to know that it saves it until you decide to go Eco Pro.
2014 M235i.Estoril Blue II Coral Red
2020 Jeep Grand Cherokee High Altitude 2021 X3M Competition.Alipine White.Sakhir Orange 2022 Jeep Grand Cherokee 4XE Summit Reserve (Current) |
03-03-2015, 07:12 AM | #19 | |
Rep 1,215
I hate this function!
MANHART MH2 400 Partout FS: MANHART MHtronik Tuning Box http://www.2addicts.com/forums/showt...5#post18819345 |
03-03-2015, 08:14 AM | #20 |
Rep 2,802
Stop start is weird. I wouldnt worry about shutting engine off too quickly. I doubt there is any scenario that could cause turbo problems short of a few hot laps on the track.
03-04-2015, 07:33 AM | #21 |
Rep 5
I dont know how u managed it, but my Stop/Start is always ON, eco / comfort / sport / sport + doesnt change a thing. And i dont like it, everytime i turn the car on, i have to press the damn button to be sure not to stop after a sporty ride /:.
I still prefer to wait 30s after a sporty ride than to turn off the engine straight on. |
03-04-2015, 07:49 AM | #22 |
Rep 2,802
