Heat problem change in temps with different fuel
01-26-2008, 05:48 AM | #1 |
Rep 321
Hey
Is it possible to have a drop in temperature when using higher octane fuel with V2 Procede? I have been running V2 on 91 AKI fuel for 2 weeks, no problems . Normal operating temps where between 250-260 depending on driving. Since i been filling up with 98 AKI the normal operating temps have not gone above 250 once even under hard driving and stabilize at 244 now when they used to stabilize at just over 250. Has anyone else experienced this? I have the standard BMW oil cooler installed. |
01-26-2008, 07:19 AM | #2 |
Rep 4,726
You're kidding right? In theory octane change can have a small effect on temps, in theory. If you seriously think your measuring a 7 degree difference well.
01-26-2008, 07:30 AM | #3 | |
Rep 321
As usual it must be you I just asking a question and stating what i observed the last couple of days. And i am measuring a 7 degree difference, when driving hard! If you would like video proof or something Im in no way saying it is just the octane, it is possible something could be going wrong when im running lower octane and same torque values, just trying to get some opinions. |
01-26-2008, 07:42 AM | #4 |
Rep 2,426
Drives: E93 335i M-sport
I guess when you run the tank dry, fill up again on the 91 and see what happens... ?
Possibly some sort of additive ? |
01-26-2008, 07:55 AM | #5 |
Rep 321
01-26-2008, 10:55 AM | #6 |
Rep 1,283
01-26-2008, 11:14 AM | #7 |
Rep 5,780
While I do not believe you could measure it and what was witnessed was pure coincidence; there could be slight merit to this.
Higher octane fuels have a lower BTU content. If you took it easy on the throttle you could possibly generate less energy and less heat. But IMO, it would probably be immeasurable. |
01-26-2008, 12:06 PM | #8 |
Rep 2,189
dont forget detonation guys. higher octane will reduce detonation making the engine more efficient & lower temps
ppp
Olds Starfire > Chevy Malibu > Isuzu I-mark RS & Honda Magna 500 > Grand Am GT & YSR50 > Nissan Maxima & Ninja 750 > X-Wife > Hyundai Excel > Honda Prelude > Honda Accord > Honda Prelude & Ninja 250> Infiniti G35 > E90 335i > Hyundai Genesis Rspec, Hyunadai Sonata > Kia Sorento > Honda CRV-EX |
01-26-2008, 01:21 PM | #9 | |
Rep 321
But ill make sure next week when i fill up on 91 again maybe it is causing problems because the car gets hotter much quicker, i do a 3rd and 4th gear run twice and its sitting on 260 today i drove the whole day hard and it only hit 250 |
01-26-2008, 01:30 PM | #10 |
2097
Rep 43,350
Higher octane fuel actually does lower your temps due to the fact that detonation is reduced and you get a more efficient burn. In terms of temps it's not as effective as running a higher compression ratio but you do tend to get a better burn and at the same AFR in comparison to lower octane fuel you'd run more rich causing lower temps as well.
