Spearco Intercooler - Pressure drop/dyno stock & 14 PSI boost
01-27-2008, 01:12 AM | #1 |
Rep 1,764
I came across these dyno and pressure drop data from Turbo-kits.com. The pressure drop data is very useful in determining how effective this IC would be at lower boost level such as with SSTT, JBS or Dinan Tune (PROcede v2 is going to have larger HP gains) for increased power.
Looks like with cat back exhaust and IC you can gain additional 25-35 WHP. I would like to see this type of data from the other IC manufactures and you should to. As far as I’m concern they show nothing but a best case scenario for marketing. Spearco is certainly using a very cost effective high performance type core and they might have an edge on everyone else unless the other manufacturer can provide similar pressure drop data. Going by this data the stock core is at the limits with 14 PSI boost. You don't want more than 1.5 PSI pressure drop. Orb Last edited by Orb; 03-10-2009 at 09:21 AM.. |
01-27-2008, 11:03 AM | #4 |
Rep 496
got my spearco coming on tuesday...cant wait for it...took me a while to choose an intercooler....i did much research and spearco was the only one i found to not play the bs games and show real numbers...thats what i determinded my choice on....i mean rpi claimed 26 rwhp gain, but i didnt trust that graph. lata
Manny : 2008 335xi sedan : SG, Terra, Alum, 6mt, SPP, PP, 162s Mods; Procede V4 | Remus Quads | UR catless dps | H&R coilovers | Modified CDV | Injen Intake | Spearco IC | Forge DVs | Defi Boost Gauge w/controller | Vorsteiner CF Hood + Front Lip | OEM M-tech Body kit | Hamann eyelids | Predator Ice Angels | 19" Volk Progressive Me's | Rotora BBK | 18" Rota Torques w/Blizzaks |
01-27-2008, 11:07 AM | #5 |
IT geek
Rep 187
I know I had to drop my V2 values DOWN by a couple of points because the Spearco IC was allowing for too much boost- peaks of 15.6-15.8 at 90%.
VS. stock, it will still show some heat soak after repeated punishing (0-120+, hard stop, 0-100+, hard stop- several times in a row), but FAR less than the stock IC and complete recovery is VERY fast. Throttle response is better too- turbo spool seemed quicker. I think in daily driving, you spool up the scrolls all the time, just not to a very high pressure- juice it a couple times and the stock IC just doesn't have time to cool down in all the way during typical city driving. The Spearco is back to stone cold in a few seconds and less pressure drop makes life easier for the turbos. |
01-27-2008, 11:24 AM | #6 | |
Rep 496
Is this true or am i gonna have to drop my torque values when the ic is installed. I was under the assumptions that the boost pressure wouuld drop and i would be able to raise the torque values back up to compensate and this pressure will now be cooler and denser air, resulting in higher hp numbers at the same boost levels? am i way off base here?
01-27-2008, 11:28 AM | #7 | |
Modder Raider
759
Rep 8,633
Drives: M3
By having a better IC, the boost values should drop instead of rise. Boost values should rise only if the air intake temps rise.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
01-27-2008, 11:44 AM | #8 |
Rep 1,568
Psi is psi...if the boost is rising in terms of psi due to the intercooler, you better reduce the torque values to keep psi in an acceptable range for the turbos. My humble opinion.
01-27-2008, 11:48 AM | #9 | |
Rep 1,764
My guess is the RPI would be 1/3 less in gains based on the bits of data I have seen when compared to the Spearco Orb |
01-27-2008, 12:51 PM | #10 |
Rep 10,587
I know my psi dropped when I put in my intercooler.......lower EGT's equals more power. I ran 350whp approx w/ no other mods than V2 at 12.4psi w/ the V2 set to 94%. Most other people are running high 14.x psi to run the same whp.
So w/ the Helix intercooler my psi actually dropped but my hp stayed up. That is why i'm waiting for Shiv to set up a tune to maximize the hp out of the cooler EGT's my intercooler is allowing.
01-27-2008, 12:54 PM | #11 |
Rep 3,523
So if the pressure drop across the intercooler is less the manifold pressure will adjusted accordingly and keep the boost at the manifold the same.
If the dp is less across the intercooler the turbo needs to work less to create the same amount of boost. Less dp so the turbo rpm is lower for an equivalent amount of boost. Isn't the boost control pressure controlled at the manifold. But this then means you can run higher boost at the turbo since the turbo has a lower rpm and can run in its safe area as compared to stock. Comments? |
01-27-2008, 01:51 PM | #12 | |
Rep 1,568
01-27-2008, 04:55 PM | #13 |
Rep 3,523
Yeah, your right on the stock hp of the car. The boost will be reduced. On a stock ECU.
My point is what is the limiting factor of the turbo? Is it absolute pressure output, RPM of the turbo, or something else? You are assuming it is pressure, and you might be right but from the Dinan postings they were limiting the turbo output due to RPM, not boost pressure. The high RPM reduces the life of the turbo. The higher RPM was naturally linked to increased boost output. But if you reduce the total pressure drop of the system then you should be able to improve turbo output, hence boost w/o higher turbo RPM. All of the performance gains on the intercooler must be in hand with some type of non-stock increased boost ECU program or piggyback. Otherwise a intercooler will really not got you any more hp/torque. These assumptions are all based on the ECU not trying to maintain stock output. If there are other engine managment issues with higher boost then all gains may be out the window. I don't know enough about the engine management system. |
01-27-2008, 06:33 PM | #14 |
Rep 5,780
There is no one single answer to whether more or less boost would be run.
* If the system is load based and a MAF, there may be less boost due to the cooler air. * If load based and speed density is used, as with the N54, the cooler air may cause a drop in boost. However, if a desired boost control value duty cycle is specified based on inputs, and not just a boost target (fine within a certain range), boost could increase due to the lower pressure drop. * If it is EBC controlled and based on manifold pressure, you will get the same boost. * If a MBC is used and referenced from the compressor, boost will increase some. * If a MBC is used and referenced at the manifold, pressure will be the same. In other words, there is no one simple answer. |
01-27-2008, 08:14 PM | #15 | |
I do screenprinting and embroiderry
11
Rep 277
Some other manufactures will have more pressure drop compared to stock in which case you would have to raise your UT settings. Not the case for the super efficient Spearco unit.
01-27-2008, 08:33 PM | #16 | |
Rep 1,764
For others, the following link give at least give you a very full overview on how an IC works: http://www.gnttype.org/techarea/turbo/intercooler.html Orb |
01-27-2008, 10:24 PM | #17 |
11
Rep 277
the data was taken from our dyno and computers at Turbonetics (parent company of Spearco for those who don't know). The test car was equipped with an RD Sport Black Box so these numbers should be replicated with PROcede V1.47 and XEDE units.
and yes, Turbonetics will no longer be selling these Intercoolers to the public. I'm waiting for my boss to let me if I can divulge more info about that... There are, however, a few Spearco vendors that still have some of these units in stock. I can help anyone find one, just PM me.
01-27-2008, 11:04 PM | #18 | |
Rep 1,764
Orb |
01-27-2008, 11:51 PM | #19 |
11
Rep 277
will do...
01-28-2008, 12:57 AM | #20 | |
Rep 1,743
01-28-2008, 01:11 AM | #21 | |
Rep 1,568
01-28-2008, 06:53 PM | #22 | |
Ironchef
92
Rep 495
The benefits of a good IC is typically less pressure drop (so your turbos do not work as hard) and increased detonation prevention (therefore you can run a more aggressive tune).
20 X3MC AW
15 F80 BSM M3, BM3 09 C63 AMG, Eurocharged Flash, Klassen Monoblocks - sold 07 E90 335, UR Exh, Helix IC, Bav Sport Coils, iForged Swift- sold E46 M3 - gone and always missed |
