Water damaged DME now with pics Update car runs with codes
03-17-2015, 05:27 PM | #1 |
Rep 120
Had my 2007 e92 off the road for the winter and sitting outside. Car was started a few months back with no issues. Thought I would get it going today and take it for a spin since the snow is nearly gone. Battery was dead flat. Charged the battery and when it is hooked up the water pump runs continuously, wipers run continuously, and car cranks but will not start. I can hear the fuel pump run. I tried scanning the car but code reader will not communicate. Is there anyone who can repair DMEs or recode a used one or am I stuck going back to BMW for a fleecing?
03-17-2015, 06:58 PM | #2 |
Rep 195
a dme recode is not possible and unfortunately the repair will most likely not work if its indeed water damage.
btw how did the water get in the dme box?? i wish you luck a new dme is like 1700$ from dealer
2008 335i coupe 6MT BOOST FIEND
03-17-2015, 07:20 PM | #3 | |
Rep 120
Car was running great too, and I guess I will lose my cobb if I can't unmarry it too. Gotta love electronics. Sometimes I wish for carburetors to make a comeback lol. |
03-18-2015, 07:30 PM | #5 |
Rep 120
03-19-2015, 12:53 PM | #8 |
Rep 3,961
They are not water proof and water around the pins coming out of the DME will seep in. Water sitting in the pin area will short circuit. So as soon as the ECU gets energized, game over.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
03-19-2015, 08:34 PM | #9 |
Rep 120
Got the car in the shop today and pulled the dme....not good. The plastic box was damp/wet inside, there was a small amount of water visible on the bottom and connectors and wires had moisture on them. Pulled the plugs on the dme on found moisture around some pins, corrosion, and one pin corroded away altogether. Opened up the dme and the boards look ok to me though I am no expert. I am going to try and solder a jumper wire at the corroded pin and see what happens...I got nothing to lose. I suspect the board and or components may have been shorted anyways.
The location of the dme is piss poor. Right below the windshield and right beside the drains...its like building your house under a waterfall and never expecting leaks. Its also close to the turbos and exhaust manifold which would cause extreme heat cycling and condensation in the "sealed" "protected" dme encloser. |
03-19-2015, 10:21 PM | #10 |
Rep 3,961
If the connectors were weather pack connectors all would have been good. Time for a new DME and harness. Hopefully BMW sells a repair harness in sections. There is probably water in the car also and the DME box fan might be fried also.
03-20-2015, 07:07 AM | #11 | |
Rep 120
I am going to try to jump the bad connector. It would be nice if it would power up and I could unmarry my cobb. I did not see any water inside the car, but did not look that close. Is the dme box fan right on one of the boards...I did not see anything external. |
03-20-2015, 08:13 AM | #12 |
Macgyver
208
Rep 942
Don't cut or solder the pins . Buy a couple of these and clean them on both the DME side and harness side. Also wipe the board dry and use a blow dryer to dry it out before hooking it back up and putting power to it.
http://www.amazon.com/CAIG-DeOxit-Cl.../dp/B0002BBV4G
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
03-20-2015, 11:31 AM | #13 | |
Rep 989
03-20-2015, 11:37 AM | #14 |
BimmerPost Supporting Vendor
24519
Rep 191,519
You either did not lock it properly, or if you have never opened the ECU box then it is the previous owner.
03-20-2015, 03:55 PM | #15 |
Rep 120
03-20-2015, 03:57 PM | #16 |
Rep 120
I have never had it open, and when I removed it both locks were in place and the tabs at the other sides of the box were latched. It was seated properly.
03-20-2015, 04:06 PM | #17 |
Rep 120
I have since jumped the bad connector with a wire and the car runs, I can communicate with the dme with the code reader. I unmarryed my cobb successfully. Car seems to run fine however the engine light is on due to some dme codes that I can't remember off hand. I may try to solder the jumper wire on the board so I can drive the car and see how it runs. Called Bmw and a new dme is 1940.00 plus 3 hours programing at about 400.00. The dme is in Germany and take at leats 2 weeks.
I believe the damage I have suffered is perhaps not due to a large influx of water but small amounts over time (the car is a 2007), and condensation in the plastic "sealed" box. Last edited by mankytron; 03-20-2015 at 04:22 PM.. |
03-20-2015, 04:17 PM | #18 |
Rep 195
damn that sucks op..i had my box open many many times and ran with out a cowl and never had an issue
03-20-2015, 04:19 PM | #19 |
24519
Rep 191,519
So how would water get in the box if it was sealed properly ?
03-20-2015, 04:35 PM | #20 | |
Rep 120
Also the connection in question must be some kind of power wire, which with corrosion would heat up and weaken the steel connector causing it to break. Most if not all the other connectors are in fine shape. |
03-20-2015, 04:44 PM | #21 | |
Rep 195
03-20-2015, 04:57 PM | #22 |
Rep 120
