Heavy smoke, rough idle on startup, help!
03-19-2015, 07:48 AM | #1 |
Rep 650
Drives: Ferrari F430, E92 M3, 335xi
Hi all,
Car worked fine in the evening, no issues when it was parked. When I go to start it up, I hear like a whistle which my wife also heard in the house, and then it starts idling bad, and most likely running on 3 cylinders max. Looking around me, I see this very thick foggy smoke , white smoke around... I don't think a turbo seal blown can happen at startup, they tend to leak before little by little... Coolant is all there, obviously it is oil... Can the PCV valve do this ? I need to take off spark plugs today and see which cylinders are flooded with oil.. Codes are missfires on 4, 5, 6 only; nothing else.... One more thing, it is stock, as I took the JB4 out a few months ago... I never got around fixing the hesitations, they seem to be less obvious without the jb4 to the extent that the car is perfectly drive-able stock. any ideas welcolme... one idea I have is to torn her apart and sell it for parts Thanks a lot |
03-19-2015, 01:31 PM | #2 |
Rep 650
Nobody ?
03-19-2015, 02:24 PM | #3 |
Rep 228
Sounds like it could be a bad injector/s did you pull the codes from the ecu ? Check the plugs for unburnt gas or oil it's all about trouble shooting at this point start with the easiest and go from there good luck
03-20-2015, 09:32 AM | #4 |
Rep 650
I pulled out the spark plugs , there is no oil anywhere, just fuel... heavy smell of fuel even after sitting one day in the garage... I believe some injectors stuck open. It complains about misfires (I mean I read the codes ) in cylinder 5, 6 and multiple misfires...
Would this be safe to assume it is injectors ? But can overly rich mixture produce white smoke, lots of it ? The only thing I did not change on this car is injectors ( I mean I replaced one, with a second hand one... worked for 10k miles I suppose, but never pulled the trigger on a set of new injectors ) . Would there be a chance to be a bad DME ? that is something I cannot test ... Thanks |
03-20-2015, 12:01 PM | #6 |
Rep 1,643
If it's a 2008 with original injectors, at this point you may as well replace them all. And if you have the old msd80 Ecu hope it didn't short a transistor - I think some early 08's had the older dme
2007 E92 335i MT
03-20-2015, 01:39 PM | #7 |
Rep 228
It's not your ecu it has to be injectors with out a doubt if your ecu fried you would have a whole bunch of issues just bit the bullet and buy new injectors just make sure to buy inpa software along with it to code them in
04-06-2015, 03:43 PM | #8 |
Rep 650
Hi all and thanks for all replies,
I bought a couple of second hand injectors before splashing out onver 1G on injectors, and it seems that it was that... engine purrs nicely now with 5 and 6 injectors changed and coded (I have INPA on a laptop). I actually bought a set of 6 new ones, index 12, so that should fix the issues... I am hoping no more problems with this car for a while... I never had any crap with my E46 M3 ( which I miss a lot ), my E36 M3, etc... These new engines are so complicated and many parts prone to failure. I am pretty sure it is also due for a walnut blast, so that's my next step for teh summer, when weather warms up (it seems that you can rent the equipment from bavarian auto ). Cheers |
