Is anyone running the HKS BOV/VRSF CP?
03-23-2015, 02:15 PM | #1 |
Rep 356
I bought this setup thinking its a quality setup as I am running TIAL and ER right now. I just wanted more noise so I bought this new setup and unfortunately I have been hearing that this setup sucks.
I have taken it to two BMW shops near me which always do good work and work with these products who turned me away. They said the VRSF CP is a pain to install and a VRSF CP with HKS BOV is just a nightmare because the oring for the BOV is too thick and doesn't allow it to sit down on the VRSF CP. I was assured this CP is the best quality and works with the HKS BOV perfectly. Anyone want to shed some light onto this? |
03-23-2015, 02:22 PM | #2 |
Rep 97
I would talk to Tiago at VRspeed. He will send you the correct size o-ring. He is already aware of this issue as there is a thread on this already.
9.29 ET -97' Awd Eagle Talon (2.2 liter long rod/ 6766 vband/ ID2000/ twin bosch 044's/ ecmlink-speed density/ Ksport coilovers/ TRE stage 3 trans/Ptt twin disk/ JM fab fmic)
08' E92 N54 Awd 335xi (KW V1 coilovers/ 18" BBS/ Alpina flash/ Vrsf CP HKS bov/ Vrsf 7' fmic/ Fuel it stage 3/ Cobb V3) Last edited by Bigboost_E92; 03-23-2015 at 02:31 PM.. |
03-23-2015, 03:31 PM | #3 | |||
2097
Rep 43,350
I wouldn't say it's fair to claim our product "sucks" when their grips is clearly with the HKS o-ring and mounting design. You'd have this problem with any chargepipe. After I was first notified of this potential issue we came up with a solution to this difficulty by providing smaller o-rings to customers when they purchase an HKS CP W/BOV. If a shop turned you away from installing a certain brand it's more likely because they want you to purchase a chargepipe from them because they don't sell that brand. Quote:
Shoot over your order info and I'll be happy to investigate this for you and get you a new o-ring if required. Last edited by Tiago@VRSF; 03-23-2015 at 05:26 PM.. |
03-23-2015, 04:41 PM | #4 |
Rep 263
I also bought this setup from your partner bad dog motorsports about a month ago.
The BOV was shipped directly from you to me in feb and AMS in linden NJ told me the same issue as OP described. Would You be able to help me out tiago? |
03-23-2015, 04:55 PM | #5 |
2097
Rep 43,350
I'm confused, did the OP buy this or did you? Either way, shoot me an e-mail/PM with your shipping info from the order placed and I'll be happy to take care of your o-ring issue (which is an HKS problem, not a CP problem)
03-23-2015, 05:02 PM | #6 |
Rep 89
i was thinking of purchasing that combo for my n54 535i.
i love the way HKS sounds, had it on my Audi back in 2004 so what are the problems with this set up?
2020 BMW M340i - Portimao Blue - Black Interior w/Blue Stitching -
03-23-2015, 06:34 PM | #7 |
3442
Rep 79,211
The only problem as of recently appear to be O rings that are a little too big. Seems like an easy fix for anyone that ran into that issue.
03-23-2015, 07:24 PM | #8 |
Rep 627
We sell a lot of these setups and other than the O ring issue, which is an easy fix, I have not heard of any fitment issues. I have also installed plenty of these and would agree they are a 3-4 difficulty level.
03-24-2015, 12:19 PM | #9 | |
Rep 710
Drives: 23 M3 Competition
03-24-2015, 07:36 PM | #11 |
Rep 20
I managed to get mine on with the o-ring that came with the bov. just gotta take the bov apart so you can get the snap ring pliers in there nice and just work it down around the bov flange with a screwdriver, don't pound on it as the bov is just cast aluminum and you'll be fine. just make sure that c clip sits in the groove, and when you think it's on good give a little yank on it to make sure the clip is in the groove and won't just pull out and you're good to go. it's a bitch but I'd rather it be a tight fit and have to work on it than have it loose and possibly leaking boost
04-01-2015, 02:11 PM | #14 |
Rep 263
Well I took this to two BMW "shops" and both suck lol. Both turned me away after having issues installing the C CLIP into the BOV flange. Told me to get C CLIP pliers and come back.
Does anyone have a DIY or anything? I am confused and might as well do this myself. |
04-01-2015, 02:33 PM | #15 |
Rep 1,681
How does a shop not have a C clip plier? It's like $15. I installed an HKS a long time ago on a friend's car and he just went to Home Depot and bought one so we could do it. The HKS should have instructions, but it's not rocket science.
04-01-2015, 02:38 PM | #16 |
Rep 263
Came with nothing. Most supplied BOV/CP setups come bolted on from factory.
Anyway, I figured I need the C Clip pliers will grab a pair today and attempt it myself. |
04-01-2015, 02:59 PM | #17 |
Rep 710
Do this with the chargepipe off the car. Remove the cover from the HKS BOV to make things easier, and not to damage the cover. Put a towel under the chargepipe and above the BOV. Use a trigger clamp to apply as much pressure as possible to compress the two. Then use the C clip pliers to finish the job.
n54_Houston0.00 |
04-01-2015, 05:33 PM | #18 | |
Rep 20
04-02-2015, 03:26 PM | #19 |
Rep 97
Lmao! Who takes their vehicle to a shop to have a charge pipe installed? If you cant do it on your own then you probably should leave it alone. I've never heard of a shop that doesn't own a pair of c-clip pliers.
No they don't. I've done complete fmic kits on DSM's, Evo's, and Gtr's and not one came assembled. What factory are you referring to?
08' E92 N54 Awd 335xi (KW V1 coilovers/ 18" BBS/ Alpina flash/ Vrsf CP HKS bov/ Vrsf 7' fmic/ Fuel it stage 3/ Cobb V3) Last edited by Bigboost_E92; 04-02-2015 at 03:38 PM.. |
