Best downpipe setup to keep 1 set of cats?
01-29-2008, 08:44 AM | #1 |
Rep 10,587
I've been pondering which way to go with downpipes. My 2 options are to go catless and keep the stock secondary cats. That would require an O2 simulator such as Terry's or the built-in capability of the Procede (once Shiv releases it). Or to go with catted downpipes and remove the secondary cats.
Has anyone tested both configs to see which give the best power gains? The best sound? Going catless downpipes and keeping the secondaries would be the most cost effective, but would it give the best flow? The cats that would be used would be the stock units, not high flow versions. also the "blockage" of the cats would be moved furthur downstream in the exhaust which should give the entire exhaust better breathing characteristics. However going with catted high flow downpipes would mean the only cats left on the car would be high flow versions. What do you guys think? I do not want to go completely catless due to noise and smell. I'm a bit torn on this one. Comments?
01-29-2008, 09:21 AM | #2 |
Rep 620
Drives: 2007 BMW 335i coupe 6MT
Are you definitely keeping the stock exhaust? If so, get the catless DPs. If you are thinking about getting a catback system, then Catted DPs might be your only option....Don't think any of the catback systems for our cars come with cats. I have the Catted DPs with AA catless exhaust. Sounds really good to me. Quiet enough when cruising but you can definitely hear it when you open up the throttle. Plus I haven't thrown any CELs
SOLD!!! :-(Space Gray Metallic - Coral Red - 6MT - Sport - AA Exhaust - UR Catted Coated DP's - Procede V3.1 PnP - Stett CAI - BMW Group SSK - M-Tech Sides/Rear- OEM Aero Lip - GP 8500K Angels - Vorsteiner Boot Lid - Miro M6 Reps |
01-29-2008, 09:26 AM | #3 |
Rep 10,587
I may keep the stock exhaust and just modify it a bit......change the rear section including mufflers and tips.
OR I have a guy ready to make me a custom full stainless exhaust using magnaflows. He could add in a set of high flow cats in the exhaust letting me use catless DP's if they make more hp.
01-29-2008, 09:51 AM | #4 |
Rep 6,608
I would go with catless DP's and then put racing high flow cats as far back in the exhaust as possible. I think this would give you the best of both worlds.
I install all tunes, intakes, o2 simms, and most cosmetic mods. PM me for a quote. |
02-05-2008, 07:41 AM | #7 |
Rep 10,587
Catless DP's and intake are on order already for Ultimate Racing. I'll report back after installed and dynoed.
02-05-2008, 09:48 AM | #8 |
Rep 1,288
Drives: 135i
That was a good choice, don't forget that cats under the hood raise temps. Putting them under the car will keep your engine nice and cool
Performance: UUC Sways CDV Mod KW V3 Vorshlag plates Pagid Yellow VK OC Hotchkis Brace STETT IC/CAI Braille B2015 VK Catless DP BMS JB3 M-Tech
#1 Mod: AutoX/HPDE HPDE 3 Many Thanks: **********s UUC Motorwerks VK Motorwerks HP Autowerks SOLD |
02-05-2008, 10:00 AM | #9 | |
Modder Raider
759
Rep 8,633
Drives: M3
This is what I would have done if I were to do it all over again.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
02-08-2008, 03:36 AM | #10 | |
Rep 2,740
