BIMMERPOST Universal Forums General BMW News and Cars Discussion Maybe the answer is " nothing"
      04-05-2015, 07:13 PM   #1
Jazzerguy
Drives: 2010 E90
From the silly questions department: Just passed 100k on my '10 E90. My first BMW (all too late in life) and best daily driver, ever. I did all the scheduled maintenance through 50 K, had my rotors worked on, then just kept changing oil and filters until now. It runs like a champ.
In fact, I finally figured out what makes me want to just keep driving this car, when I'd typically have new car fever by now: It drives like the day I bought it.
Should I be focused on any further service items, or just watch to see if / when any sensors tell me otherwise?
I do have one issue. A light bulb error message. I have a hairline crack in one lens cover, but all,of my lights work properly
What say ye?
      04-05-2015, 07:44 PM   #2
ShocknAwe
1Addict
ShocknAwe's Avatar
3627
Drives: E82 Mutt, M57 X5D
What say ye?
Trans fluid, diff fluid, brake fluid, power steering fluid, check the belts, check brake pad level, start thinking about replacing vacuum hoses. Has your water pump gone out yet?
2010 E82 1 Series M Clone
Hydra Performance augmented OEM+
      04-05-2015, 08:16 PM   #3
Jazzerguy
Drives: 2010 E90
I've heard mixed reviews on transmission and differential fluid, but that sounds plausible. Water pump has been fine this far.
      04-05-2015, 08:19 PM   #4
ShocknAwe
1Addict
ShocknAwe's Avatar
3627
At the very least change the fluids and replace with fresh OEM fluid. They are absolutely not lifetime fluids.
      04-06-2015, 03:05 AM   #5
DocWeatherington
DocWeatherington's Avatar
Drives: F90 CP
2024 XM  [10.00]
Tranny that's a hard on.. I say, just make sure your taking it in for checkups... Do you have a trusted dealer or mom/pops shop?
An Congrats.. on the milestone...
But something tells me your going to get another BMW
      04-06-2015, 06:13 AM   #6
Chihuahua
Chihuahua's Avatar
4531
Drives: E30 329iS, E65 Alpina B7
+100000000000000000000000
Check ZF literature for recommended service intervals. at 100K, you are way overdue. There is NO such thing as 'lifetime' fluid on these cars.
      04-06-2015, 06:37 AM   #7
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
What E90 is it and what transmission type?
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
      04-06-2015, 12:01 PM   #8
cenix
cenix's Avatar
Drives: E90 M3 ZCP
You may even start considering looking at your suspension components and checking to see if they are still in good condition, like bushings, ball joints, axles/boots, dampers, etc. Also check alignment.
      04-07-2015, 11:37 PM   #9
Jazzerguy
Drives: 2010 E90
Thanks for the help. I starting with spark plugs and differential fluid. I did oil, air and cabin filter. Will also have them check suspension components and other fluids
      04-07-2015, 11:43 PM   #10
Jazzerguy
Drives: 2010 E90
Thanks for he help, gentlemen ! I'm starting with differential fluid and spark plugs. Oil, oil filter, air filter and cabin filter replaced. I'll have them check other fluids and suspension components as well
Cheers
(And yes, I'll probably buy another one some point
I have a '54 Bentley and '89 560Sl with 26k miles to keep me distracted ...
