Splitter thing on front bumper...
04-13-2015, 03:05 PM | #1 |
Rep 1,596
I've noticed since having the undertray off the car last week to do the thermostat and things, i've got an air deflector thing hanging down on the bumper:
https://www.dropbox.com/s/n48132ktsg...58.49.jpg?dl=0 I've had a look and there appears to be a fastener or something missing, i pushed it back up into place and this hole in the bumper lines up with a hole in the flap thing, but theres nothing to go into it? https://www.dropbox.com/s/b8l4rjzsu0...06.03.jpg?dl=0 The other side is the same, with nothing in that hole, both flaps just have a single screw on the outer edge. Anyone know whats supposed to go in there to hold it inplace? |
04-14-2015, 04:07 AM | #2 |
Rep 1,596
http://www.realoem.com/bmw/showparts...1&fg=55&hl=122
I think i've found it on there, item 7... BUT, i've still no idea what fasteners are supposed to be used, its really not clear on that at all! |
04-15-2015, 02:47 PM | #5 |
Rep 1,596
yeh i thaught something along those lines too, but 15 i think is quite a bit smaller. The hole in the plastic thing and the bumper is really quite large, 10-15mm at a guess.
the item 13 in the circle suggests 6 screws are required to fix them, presumeably 3 per side. The one screw thats there does look like 13, but i cant see what the other two would screw into?! |
04-15-2015, 02:50 PM | #6 |
Rep 1,596
Ah interesting....
http://www.ecstuning.com/ES129310/ My flap looks like its worn away, its shorter than that pic and you can see the worn edge on the inside. |
04-16-2015, 07:34 AM | #7 |
Rep 75
I am interested to see what you end up doing mate, you will find that they get worn from rubbing on kerbs etc when you are parking up , as mine are the same, and also no fittinsgs, I do wonder if they have popped out at some point due to the splitter thing being flexed too much,as it's rubber so bends well.
I have been tempted to use a couple of short mushroom head bolts with nylon nuts , only thing I worry is if parking too close it may just rip a hole in the bumper :-s ,so hoping someone,or you has a fix lol . |
04-16-2015, 10:01 AM | #8 |
Rep 1,596
Boss at work has a 335d so had a squint under it at lunch time.
His is fixed with two screws and two rivets: https://www.dropbox.com/s/rrbyo3ls3u...30.48.jpg?dl=0 https://www.dropbox.com/s/8rq4fk84gl...30.53.jpg?dl=0 I think i've found the screw and the rivits on realoem, so i'll order them when i get a chance and keep you updated. |
04-16-2015, 10:08 AM | #9 |
Rep 351
I thought this was just me when I took a look under my 320 some time back, I'm also missing a few screws/rivits on the underside.
