Boost Issue on V2
02-03-2008, 12:34 AM | #1 |
Rep 178
Boost Issue on V2
I installed the MSDS CAI and decided to run some data logs. The only mods I have at the moment are V2, plus the intake. My questions arise up as my torque settings were at 94% with a peak boost of 13.8. I'm running shell 92 octane but my bud has the settings at 94% with peak boost at 15. I would have thought the intake would increase my boost. I was very careful to secure everything properly. Any thoughts to why this may be?
Much Obliged, YB |
02-03-2008, 02:27 AM | #2 |
Rep 1,310
Every car is different and will react differently to mods introduced into the system. If I was you, I would reset the torque settings to default 90%, shut everything off, then disconnect the battery for an hour. Then reconnect and follow Eugen's suggestions for adaptation. Don't expect immediate gains. Give it a week of daily driving adaptation and datalog to see how the boost increases each day...
02-03-2008, 07:18 AM | #3 |
Rep 2,278
I've had my V2 for a week. With the help of e90 ice we datalogged yesterday and at 90% I am getting boost to 14.8. I am happy with the tune. And I've had absolutely no problems with either V1.47 or V2, but then I am a lagger.
2015 f80 M3, 2016 GT3
02-03-2008, 08:58 AM | #4 | |
Rep 390
I think your setup is very similar to mine and i was experienceing the same side effect... I saw this especially when it was 40 degrees or less outside (about 12psi average) now that the weather is warming up I see higher levels (more like 14psi average)
See Shiv's comment about Boost Level from a thread I started... Quote:
02-03-2008, 09:23 AM | #5 |
Rep 822
Isn't it the case that a CAI will drop boost pressure compared to an otherwise stock motor?
I think that a CAI will cooler air that is more densely packed with Oxygen. As the air contains more Qxygen, the same bhp can be achieved at lower (and therefore safer) boost pressures, as the OP is experiencing. A CAI will not actually provide more power per se, but will provide the opportunity to increase the V2 user torque curve higher, say 98%, to achieve a max recommended boost pressure of 15psi and achieving higher bhp as a result. Wrong? |
02-03-2008, 09:46 AM | #6 | |
Rep 2,002
02-03-2008, 11:38 AM | #7 |
Rep 178
Morning!
I'll reset the battery and follow Eugene's adaption suggestions, Check my intake, and then crack the throttle open. Post my results soon. Thanks for all the information. Oh yeah, Patriots FTW! |
02-03-2008, 06:43 PM | #8 | |
ocasionally in crisis
52
Rep 2,358
can u provide a link, or post it here, or even a PM would be great. thanks
If your car isn't scary - it's just not fast enough !
RPI IC / UR catless DPs / JB3 2.0 beta / UR CAI / Quaife LSD / Snow Methanol Injection / VK oil cooler upgrade / Forge DVs / M3 rear sway / Riss catch can / Paddle shifting 6AT / M Sport steering wheel / Logic 7 / Dunlop Direzza Z1 255/235 / |
02-03-2008, 07:17 PM | #9 | |
Rep 2,339
