E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Coolant reservoir sounds
Reply
      04-18-2015, 12:20 PM   #1
Chitown335i
Drives: 2007 Smoky Graphite 335i
Ever since I did a coolant flush I have heard the "bubbling" of the cooant in the reservoir. The shop I took it to says they are sure they got all the air out of the system and bled it right (they only work on BMW's) Maybe I was just unaware of the sounds before? I also do not get any hot air from my vents....
07 335i...M2 exhaust...Macht Schnell DP's...VRSF 7" FMIC...MMP inlets....VRSF Chargpipe with HKS BOV....MHD w/WedgeTuning.... RB Stealths!!!....MFactory LSD...Stage 2 Fuel It...N20 map sensor....265/40/18 Sticky Mickeys in the rear
      04-18-2015, 12:47 PM   #2
blackturbo
blackturbo's Avatar
Drives: 335i
You can bleed the air out of the system yourself if you like. Theres a youtube video that shows you how.
As for the no hot air from your vents im sure someone can chime in on that one
      04-18-2015, 12:51 PM   #3
Chitown335i
But if they already did that would I have an issue with the eservoir bubbling or are you assuming they didn't bleed ALL the air out?
      04-18-2015, 01:19 PM   #4
blackturbo
blackturbo's Avatar
Drives: 335i
It doesnt hurt giving it a try on your own, and if the problem persists others can chime in. Im just offering a suggestion to help because i had a coolant flush and there was still air in my system, sir.
best of luck
      04-18-2015, 05:27 PM   #5
N54Bob1988
Drives: 2007 335i
To bleed
Car ignition on engine off
Temp settings max (85?)
Fan speed at lowest setting
depress accelerator pedal 100% for about 10 seconds
you will here the water pump start
It will run though the bleed process and stop on its own
Reply
e90post
