Popped my hood to this.. What should I do??
04-18-2015, 05:18 PM | #1 |
Boosty
55
Rep 325
I attached a picture of my methanol line.. Obviously this hard rubber tube can't handle the heat.. Lol
What do you guys use for methanol tubing...? I bought this kit from a member and he included a roll of this tubing.
'08 335i AT Alpina Flash~Rob Beck Turbos~Full kittyless exhaust~DCI~5" Intercooler~Chargepipe BOV~BMS meth kit
04-18-2015, 05:43 PM | #2 |
Rep 375
Try silicon tubing like the ones for vacuum lines. You could probably get whatever diameter that is at whatever length you want from any auto parts store like pep boys or something.
04-18-2015, 07:39 PM | #4 |
Boosty
55
Rep 325
I did sorry lol
What should I run????
04-18-2015, 09:22 PM | #6 |
///Member
50
Rep 327
Dam,your crazy. definitely redo that.can buy nylon 11 tubing 1/4'' or 6mm.1/4 is common.
coolingmist,devils own,Burgertuning are 3 popular places to buy.
E90 335i Auto, Cold Weather, & Sports Prem. Package, Navigation
Mods: JB4/MHD, ACF ST, Precision T/S 6062, AD-Eng Mounts, PrecisionRaceworks STG_3+LPFP,//HPF Exhaust Titanium Tips, Custom HighLow OCC, Precision RaceWorks Coils,RACE InterCooler, Custom Meth Kit, v8Bait(Justin)Tuning |
04-18-2015, 10:03 PM | #7 |
Rep 2,872
04-18-2015, 11:32 PM | #8 |
Boosty
55
Rep 325
Thanks guys
I feel so dumb lol. I'm glad everything is okay
04-19-2015, 05:31 AM | #9 |
Rep 2,387
It needs to be rated for both the type of fuel and also the pressure. A guy on here ran similar kind of tubing as you did though the interior, had your kind of break except inside...filled up the whole under carpet area with meth. He's lucky to be alive.
04-19-2015, 12:16 PM | #10 |
Rep 954
Meth eats rubber it wasn't the heat that did that brother. Meth burns invisible. After you go to SS wrapped PTFE lines or nylon (no other) make sure to wash your engine bay and degrease it to nothing crazy happens. The foam cushions under covers fill up like little death sponges and spontaneously combust causing some bad under hood fires.
cp-e GTX3071R TT kit, cp-e quad exhaust, cp-e fuelbar, Stage 3 LPFP+lines, AEM EFI, Custom Meth kit, Apex EC7 18s w/R888 295s, Stoptech, M3 front, m-sport rear, cp-e difuser, Custom Headlights, CFS Radiator, Custom OC, 1000hp Lvl10 trans, DSS Axles, MFactory LSD, DEFIV lockdown kit, M3 refresh kit, KWv2's, cp-e project "4doorbmwpower"
04-19-2015, 12:17 PM | #11 |
Rep 954
When doing anything with chemicals or heat you must be sure to pair with the correct compound of hose or tubing
04-19-2015, 01:19 PM | #12 |
Boosty
55
Rep 325
Wow I appreciate the feedback. I'm so lucky something bad didn't happen!!
04-19-2015, 03:10 PM | #13 |
Rep 137
Just go to your local plumbing store. They have tubing that is rated for chemicals and high heat/pressure. I've been using it for over three years with no issue. Really cheap too.
04-19-2015, 03:18 PM | #14 |
Boosty
55
Rep 325
Oh okay. So you think advance auto parts would have something?? What's it called?
04-19-2015, 04:40 PM | #15 |
Rep 801
Nope , online only
14 M5 / comp / CCBs / alpine white
PG intakes Evolve tune Switzer exhaust Fabworx pipes |
04-20-2015, 08:29 AM | #17 | |
Rep 303
04-20-2015, 09:22 AM | #18 |
3442
Rep 79,211
Ideally, stainless steel braided lines. Or use specific methanol tubing (Nylon) from actual methanol distributors like Coolingmist, devilsown, AEM, ETC.
I dont think local auto parts stores carry what is needed. The cheap stuff at local auto parts stores wont stand up to the corrosive properties or pressure, trust me, tried that years ago and it failed miserably. There is no specific name but it needs to be tubing able to withstand the pressure and corrosive properties. You should pick up about 20-25 feet just to be safe. With 25 you will have extra. |
04-20-2015, 09:36 AM | #19 |
Rep 6,478
Stainless...You can do methanol cheap, or you can do it right. There isn't/shouldn't be a middle ground on this one, the risks are too high.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
04-20-2015, 10:16 AM | #20 |
Rep 516
http://www.mcmaster.com/#5180k71/=wu2m4m
This stuff works great, high temp, compatible with meth, and low cost. I've also bought this in the past for meth and it works also but I prefer the black color tubing to make the install look clean. http://www.mcmaster.com/#9685t3/=wu2n5o |
04-20-2015, 10:23 AM | #21 |
Rep 1,392
ugh, No wonder meth gets such a bad name. Do it right the first time. If you've never installed or had a meth kit then research it. Its a good, expensive, and reliable system that is made bad, cheap and unreliable.
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
