SSTT & Oil Temperature
02-03-2008, 10:50 PM | #1 |
Rep 119
My 335i seems to run 'warm' with oil temps between 230 - 250 with the outside temps at about 30 degrees. These oil temps are reached when I drive spirited.
Do I have to worry about excessive oil temps if I decide to buy and install SSTT? Are my my current temps normal for winter? Thanks! |
02-03-2008, 11:30 PM | #3 |
Rep 1,137
As far as I can tell, the SSTT has no effect on oil temperatures whatsoever. My car runs exactly the same with it in or out. Don't sweat it.
2010 Evo X - silver with a big, stupid wing on the back
2009 VW CC - Black/Black - with a 2011 328i on order to replace it - ED 8/1/11 |
02-04-2008, 10:44 AM | #4 |
ASR Turbos+LSD+Meth= :D
73
Rep 1,517
Drives: E92 335i
yeah mine ran the same in miami, and now in upstate NY runs even colder, espeically with the new FMIC, i run about 20 degrees cooler crusing, until i drive harder.
2007 335i Coupe Mods: Check the Garage |
02-04-2008, 11:18 AM | #5 |
If You Aint First, You're last !!!
91
Rep 2,509
it's normal.
08 BMW BSM 335i 6MT (Sports, Premium, NAV, PDC, AS, IPOD, HD Radio, Rear Sunshade, OEM Alarm) Angel iBright V3, Luminics Fog Bulb, Turbo Tuner, K&N Drop in Filter, Dinan Exhaust, Dinan Pedals, Vorsteiner CF Front Lip, and CF Rear Diffuser. Ordered:08/25/07 Started: 09/09/07 Finished: 09/14/07 On Ship: 09/15/07 Arrived: 10/08/07 Delivered: 10/10/07 |
02-04-2008, 11:19 AM | #6 | |
Rep 197
...ditto.
Alpina B4S
M8 Competition coming soon |
02-04-2008, 06:51 PM | #9 |
Rep 111
Same here.
2014 X5 35i (w/N55 Stage 1 Tuner)
2012 C6 Vette (w/Supercharger) |
02-04-2008, 09:19 PM | #10 |
Rep 372
My car, bone stock, runs in the 290-300's when pushed. Want to SSTT it but the high temps concern me. On the other side the HP I need. The Dinan Oil Cooler is out of the budget for now. Thanks guys for any suggestions.
Georgie Vazquez Mayaguez, PR R.I.P. 335i, 010 135i here! |
02-05-2008, 08:55 PM | #12 |
Rep 1,137
Again, the SSTT should not have any effect on oil temperatures. The ONLY possibility (and I am highly skeptical about this) is if you consistently run at WOT over 6,000 RPM for extended periods of time. Then I could see the added boost and lean mixture making things toasty. However, I ran my car on a track for 20 minutes at a time with the SSTT in and never had an oil temp problem. I honestly wouldn't worry about the SSTT impacting your oil temp.
02-05-2008, 09:52 PM | #13 |
Rep 372
I do not have the SSTT but did 6 laps on a short track and it went into Limp Mode, but thanks a lot for your tip! Looking forward into modding the car!
02-05-2008, 10:51 PM | #14 |
Rep 1,736
Drives: '09 E92 335i
On '07 E90, AT, with retrofitted oil cooler, I run 240-245 routinely. On my first brief romp with SSTT, today, I quickly went up to 250 (haven't hit that temp since before the retrofit). I think it would have gone higher w/ more romp time, but don't know for sure. Makes sense, higher boost, higher temps. I hit 280 just sitting in traffic before retrofit, so 250 with the SSTT seems relatively cool.
