Smoking clueless...
04-27-2015, 09:58 AM | #1 |
Rep 632
Smoking clueless...
Alright, I'm at a complete loss here... I've tested the solenoids, I've checked all the lines, everything I can do I've done and I am now on my third set of bum RB's. I can't fathom having bad luck alone so what could be the root cause of failure here? I'm thinking something in the boost actuation system but I don't know what else I can check. Logs were looking fine the last I ran and I don't really feel comfortable doing a wot log now knowing that something in there is messing up. The smoking is constant on throttle, lifting off throttle, etc.. Any help would be appreciated!!!!!!!
2007 335i e90 6mt | Motiv 750 XR8267 | RB PCV | JB4 G5 | MHD Pump Flash | Walbro 255lph | VRSF CP & Tial BOV | NGK Plugs | Custom Side Exhaust | CxRacing FMIC | Spec 2+ & SSMFW | StopTech Drilled/Slotted Rotors | Hawk Performance Pads | DEFIV Lockdown kit | Mtec V3 | Apex PS7s | 35/15% Llumar ceramic
04-27-2015, 10:47 AM | #2 | |
Rep 1,084
Have u done a compression/leak down test yet? Do you have any oil in your exhaust tips or anything? You mentioned you were on your 3rd set...what happened to the prior 2- same smoking issue? I'd be very surprised if all 3 were bad : / |
04-27-2015, 11:00 AM | #3 |
Rep 6,478
Get compression across the motor, that will rule out a lot of potential issues.
It's unlikely that three sets of RBs have all had oiling issues, but it wouldn't be out of the realm of possibility. IMO stock frame solutions will always have oil control issues, but I agree it seems unlikely that the turbos are the culprit at this point. Are you certain it is oil that is burning up?
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
04-27-2015, 11:41 AM | #4 |
Rep 632
I'll have to do the compression/ leakdown test. And no oil in the tips, I haven't had a chance to pull the dps and check axial play in the turbos yet. It's burning about a quart every 10-14 days.
04-27-2015, 11:48 AM | #6 |
Rep 632
Well it's burning oil so yeah it smells lol but no there's none under the car.
04-27-2015, 11:59 AM | #7 |
Macgyver
208
Rep 942
What about your PCV ? Has it been changed before? Is it possible as other people have mentioned that when it goes bad it starts to suck oil into the intake. If you disconnect it and the problem goes away after some miles of driving ( burns off oil already inside) then you may be on the right track. Or if it is disconnected and it stops smoking at idle. Just a thought.
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
04-27-2015, 12:10 PM | #8 | |
Rep 1,084
Flapper could be stuck open maybe?? That's a lot of oil to be burning tho.... Best bet may be pulling the downpipes and checking |
04-29-2015, 11:47 AM | #9 |
Rep 632
Yeah the car will be down for a few weeks while we go through the ropes. Thankfully I have a Harley and the weather is nice!
04-29-2015, 11:48 AM | #10 | |
Rep 1,084
