Tial BOV Flutter
04-30-2015, 08:30 AM | #1 |
Rep 18
Tial BOV Flutter
So I just recently installed a VRSF Charge Pipe and Tial BOV, other mods include JB4, DCI, and BMW PE. I seem to be getting inconsistent flutter when shifting at lower boost (2-4psi).
I've done extensive searching but can't seem to find a definitive answer as to whether this is acceptable or not. It never happens while on the throttle or at high/no boost so I can't imagine it causing any damage other than being an annoyance. Any input is welcome! |
04-30-2015, 08:52 AM | #2 |
these are the times that try mens soul's
37
Rep 280
is the flutter coming from the BOV? if so try adding a spacer in the BOV.
2008 monaco blue 335i sedan
STOCK |
04-30-2015, 08:53 AM | #3 |
Rep 18
The only part that has changed since the flutter started is the charge pipe and BOV. The way I understand BOV's adding a spacer would only make the sound worse as that is comparable to stepping up a spring size. If anything I would want to go down to a 10lb spring to allow the BOV to open easier under vacuum.
04-30-2015, 09:17 AM | #5 | |
Rep 18
Even though I don't think any damage will come from a bit of flutter at low psi I'll probably try running the 1/4" vacuum line straight from the BOV to the manifold instead of using the adapter to the factory line. If that doesn't help possibly a 10lb spring. |
04-30-2015, 11:17 AM | #6 |
Rep 2,084
11psi spring is common for N54. I tried it and I got a lot of flutter. I went down to a 10psi spring and it helped a lot, but there is still some flutter on low boost. High boost is perfect. It is not open at idle.
These things also need time to "break in". Give it a few weeks before deciding to change the spring.
2013 135is DCT Carbon Black Metallic |
04-30-2015, 11:27 AM | #7 | |
Rep 18
04-30-2015, 11:29 AM | #8 |
Maximus Decimus Meridius
1132
Rep 4,586
Don't know much about the issue, but OP your name is pretty hilarious lol.. Great movie haha...!
F30 335i Melbourne Red Metallic M-Sport Package |
04-30-2015, 11:42 AM | #9 |
Rep 2,872
Check vacuum lines and ensure they're all in good shape, mainly the one that connects to the BOV.
I believe they ship with an 11lb spring, however Tony@VTT suggests a lighter spring to eliminate the flutter. I forget the exact one, but it was about 8lbs. |
04-30-2015, 12:12 PM | #10 |
Rep 2,084
For Tial Q they have 12, 11, 10, 8, and 6 psi springs for turbo applications.
I might try an 8psi spring but it will definitely be open at idle, which isn't a problem if air is coming out. But I'm worried that it might suck air in on overrun or something.
04-30-2015, 01:24 PM | #11 |
2097
Rep 43,350
10 is the lowest I'd ever run on this car. If you need anything lower than a 10 psi spring, you have vacuum leaks. We've helped dozens of customers who require a "lower" spring and after a boost leak test they find out they have cracked vacuum lines or broken nipples on the vacuum canisters. Defective solenoids, poorly coupled connections, lack of o-ring on the BOV, TMAP or throttle body could also cause leaks
04-30-2015, 03:25 PM | #12 |
Rep 622
OP are you using the stock 1/8" vac line from the manifold, Tial states a dedicated 1/4" is required, curious as I will be throwing on my CP and Tial next week
04-30-2015, 04:03 PM | #13 |
Rep 18
VRSF provided a 1/4" line and a 1/4" to 1/8" adapter that I'm using as the provided 1/4" wasn't long enough to reach from the BOV to the plastic nipple on the manifold. I'm thinking of going out and buying one that is long enough and removing the stock line from the picture, but I'm sure the plastic nipple is the restriction at that point.
04-30-2015, 04:14 PM | #14 | |
Rep 2,872
04-30-2015, 04:39 PM | #15 | |
Rep 18
So just to be clear, having some BOV flutter when shifting at partial throttle and say 2-4psi won't cause any harm? Just more annoying than anything? |
04-30-2015, 05:09 PM | #16 |
Rep 2,084
I am thinking about doing this, or at least adding a second fitting to the manifold.
04-30-2015, 06:24 PM | #17 |
Bavarian Love
24
Rep 263
I'm having some flutter issue as well (randomly on low boost partial throttle as well) but not very often but yes I do sometimes. I am using the hose provided by ER on the stock nipple (not sure on sizing but pretty sure it's 1/4). It's been dointg it a lot less (still happen rarely from time to time) since I removed my boost gauge that was teed in the stock hose and connected the bov directly to the manifold (via the stock nipple). I too think the stock nipple is the culprit but not really looking to drill manifold (at least for now).
08 FG2 Civic SI FBO - SOLD
09 E92 335i Xdrive FBO - SOLD 17 F22 230i Xdrive | Alpine White | Coral Red | M-Sport | BMS Intake | JB4 | 666M Rep | M Carbon Mirrors | Roof Rack | Daily Driven |
05-01-2015, 09:20 AM | #18 |
Macgyver
208
Rep 942
I had the same situation with low boost flutter and when I went to visually check the hoses, the 1/4" hose at the bov was trying to back itself off. I used a tie strap to hold it and figured that was it. Drove it again, still flutter. Was about to remove 1/8" hose and brass adapter by razor blade when I realized that the 1/4" hose inner diameter was a perfect fit over the 1/8" hose. So instead of using the razor to take the 1/8" off, I left the 1" of it on the manifold and slipped the 1/4" over it and I have not heard flutter since.
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
