Auto trans manual mode
05-03-2015, 12:59 PM | #1 |
Rep 179
I was wondering if anybody could explain what exactly happens when you put your auto trans in manual mode. It seems like there is more going on than just changing ratios etc. is there some remapping going on with engine also ? Just curious! My car is a 2011 328i base.
Thanks |
05-03-2015, 01:15 PM | #2 | |
Rep 1,980
Also, a slight correction: the gear ratios are fixed, it never changes no matter what you do (it's set by the size of the sprocket). |
05-03-2015, 01:27 PM | #3 |
Rep 179
Yeah I understand that, but it does drop out of over drive when you put it in manual mode. The performance characteristics seem to change.
05-03-2015, 01:32 PM | #4 | |
Rep 1,980
05-03-2015, 02:39 PM | #5 |
Rep 1,465
Drives: 2009 BMW 335xi
Probably much like sport mode, it locks up the torque converter.
05-03-2015, 03:01 PM | #6 |
Where'd my VTEC go?
481
Rep 6,067
The ATs in this car are programmed to lockup the TC after setting off from a standstill.
DS mode probably sharpens up throttle response, but it will holder lower gears much longer and stay out of the top gears as much as possible to provide better response and a sportier feeling. Maybe 1-2 gears lower than it would in normal D mode. I don't know if theres anything that says for sure it changes the throttle, but even just being in lower gears the car will feel more responsive and quicker.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
05-03-2015, 04:10 PM | #7 | |
Rep 179
05-03-2015, 06:00 PM | #8 |
Master Bates
80
Rep 495
Try the Alpina TCU flah
CURRENT: 2020 G20 M340 xDrive — Carbahn Tune
RETIRED: 2011 E90 335i xDrive — Cobb AP3, PE Exhaust, Alpina TCU Flash, VRSF Charge Pipe 2017 Estoril Blue X1 M Sport — JB4 |
05-03-2015, 07:55 PM | #9 |
Rep 1,744
05-03-2015, 08:23 PM | #11 | |
Master Bates
80
Rep 495
Mobile apps at their finest.
05-03-2015, 10:24 PM | #12 |
Rep 179
Stayed away from 335 because I noticed so many lemon buy backs on eBay. Would still love to have one though. However I really like this car even though it's a little light on horsepower. Thanks for trying to help guys.
05-04-2015, 07:35 AM | #13 |
Rep 308
Drives: 2007 328i
From what I can tell....
it stays out of 6th gear... shifts are quicker/firmer goes from being softcore to hardcore lol. For me response gets raunchy compared to D mode. One side note... been trying to solidify my query... I swear that in M mode, if you quickly tap to shift up vs just a slow pull it shifts faster. |
05-04-2015, 07:40 AM | #14 |
Rep 1,062
A monkey is released from it's kage, depending on if you shock its ass (upshift) or chest (downshift), it goes into your transmission and manually shifts it for you. With the Alpina flash he is known to work faster although it generally pisses of his parents.
Sideways is the way of life.
05-04-2015, 10:07 AM | #15 |
Rep 2,554
It try's to keep the RPMs near the powerband. typically around 2700-3200 rpm and if it goes any higher than that it'll shift unless you're driving aggressively. I use manual mode for the sharper throttle response but I'm looking to get a true MT for I hate Autos even though the ones in our cars are rather good.
05-04-2015, 10:41 AM | #16 | |
Rep 1,980
05-04-2015, 11:21 AM | #17 | |
Maximus Decimus Meridius
1132
Rep 4,586
Thanks!
F30 335i Melbourne Red Metallic M-Sport Package |
05-04-2015, 02:17 PM | #18 | |
Where'd my VTEC go?
481
Rep 6,067
05-04-2015, 02:40 PM | #19 | |
1132
Rep 4,586
05-04-2015, 05:21 PM | #20 |
Rep 179
when you put it in manual while driving the rpm jumps up a little like it has switched out of an overdrive mode. the tranny is probably programmed to help get the best mileage when in auto maybe. when you go into the manual mode it is just that, it is supposed to hold whatever gear your in until you change gears like it would be if you had a manual transmission. I was wondering if the computer changed anything regarding the engine also. such as valve timing, throttle response etc.
