E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > picture of plugs,N54,what do u think?
Reply
      05-06-2015, 09:50 AM   #1
Nordic335M3
Nordic335M3's Avatar
Denmark
20
Drives: 335i M3 Look
Hey all
pulled the newly installed plugs today , because I have heavy oil burning exhaust smoke.
and stumbling idle..
what do you think?... Number 2 looks black and wet to me.. is this the cause?
      05-06-2015, 09:51 AM   #2
335NJ
Drives: 2008 335i 6MT E90
Valve cover gasket leak?
      05-06-2015, 10:00 AM   #3
Nordic335M3
Denmark
20
would that cause wet black sparkplug tip and heavy smoking?..
oh and tried opening oil cap with engine on.. didnt cause any change in idling, nor did I feel any vacuum...
my worst fear is worn piston rings...
I kinda hope its just the injector on that nr 2....
have no codes btw...
      05-06-2015, 10:00 AM   #4
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Try smelling number 2, does it smell like gas or oil?
(After re-reading that, it sounds funny LOL). But in all seriousness, smell it.
      05-06-2015, 10:14 AM   #5
Nordic335M3
Denmark
20
what would either smell then indicate?.. fuel=injector, oil= ?
      05-06-2015, 10:25 AM   #6
07chupacabra
Drives: 07 E92 335i
You didn't smash the N54 and S65 together did you ? I see you have a 335i M3 coupe. Just wanted to make sure.
Oil would indicate Valve Cover Gasket. How many miles do you have on the car? Oil is most likely from the VCG although it could be other things.
      05-06-2015, 10:32 AM   #7
Nordic335M3
Denmark
20
just E92 with M3 exterior
its a high milage engine.. would be nice if it was only VCG.. but I dont get how its related to oil getting in the cylinder ..anyway will change it though, and the PCV hose.. have RB PCV valve installed..
      05-06-2015, 10:33 AM   #8
Oil could be an indication of the valve cover gasket leaking usually.
      05-06-2015, 10:54 AM   #9
Nordic335M3
Denmark
20
wouldnt that give oil leak/vapor in the engine room?
      05-06-2015, 10:55 AM   #10
Not necessarily, could just be leaking between cylinders. It's a common failure point.
      05-06-2015, 11:14 AM   #11
Nordic335M3
Denmark
20
oh I see.. I really hope you are right..
worn piston rings would really make it a rainy day..
      05-06-2015, 11:17 AM   #12
Well you can check that with a compression test kit. You can find one of those at any auto parts retailer usually.
Unless you've done something deserving of a worn piston ring, it would be very unlikely.
      05-06-2015, 11:21 AM   #13
335NJ
Gross
      05-06-2015, 01:40 PM   #14
Nordic335M3
Denmark
20
Im having a compression test done monday morning.. fingers crossed
      05-06-2015, 01:41 PM   #15
Nordic335M3
Denmark
20
Gross
a smelly nr 2 is not uncommon
      05-06-2015, 01:48 PM   #16
07chupacabra
Drives: 07 E92 335i
I had the RB PCV valve installed recently too, among quite a few other things and I feel like I'm losing oil at 2-3x the original rate.
      05-06-2015, 02:17 PM   #17
Nordic335M3
Denmark
20
really??... that sucks... have you changed your VCG ?
mayby I should try swapping out the RB PCV again, just to see if there is any change...
      05-06-2015, 03:09 PM   #18
07chupacabra
Drives: 07 E92 335i
I changed the VCG and VANOS around 35k. OFGH, tie rod, Walnut, turbos, walnut blasting & RB PCV valve around 48k. Since those last 4 things were done together it's a bit hard to determine the cause. I havn't checked for leaks around the turbos yet though, not sure if the dealer replaced the turbo oil lines. I checked my plugs the past weekend (currently at 55k) and #2 looked just like yours and was reeked of fuel. Also right around this time the power steering return lines were just done as well as front control arm bushings.
Previously when my VCG went bad I had oil in spark plug well #3. Hope that helps. I'm doing my injectors today or tomorrow if the rain lets up.
      05-06-2015, 04:27 PM   #19
924er
Drives: e92 335i '10
If it reeks with fuel that means your injector is leaking bro. Let us know how that goes I'm sure that will cure the problem. Good luck!
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV,
VRSF 5in FMIC, BMS Downpipes COBB e30
      05-06-2015, 09:07 PM   #20
AndyW
Supreme Galactic Commander (one galaxy over...)
AndyW's Avatar
Drives: '08 E93, '12 E82, '13 E93 M3
My #2 plug looked like this when I replaced plugs as well...getting close to just pulling the trigger and replacing all the injectors and VCG. Car has 102K.
Best,
Andy
'12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune
      05-11-2015, 12:22 PM   #21
Nordic335M3
Denmark
20
bummer the compression tester didnt fit the 12 mm plugs...
Got a new valvecover gasket & PVC hose, so is changing that tomorrow...
man I hope it stops smoking like a SOB after that...hate seeing that huge cloud comming out the rear..
(but Not sure how leaky valvecover can cause oil leak into the cylinder...?)
      05-12-2015, 06:08 AM   #22
Nordic335M3
Denmark
20
ah just realised someone was misinforming me.. oil from leaky valve cover gasket, does NOT get into the cylinder to foul up plug tips....it can leak down on the outside, down the plug well...
Reply
e90post
