Anybody ever index plugs for the 335?
05-11-2015, 03:57 PM | #1 |
///Member
50
Rep 327
I find my stock bosch plugs run smoother then my ngk 5992 plugs. One suggested to index them. If so which way you want them to face? The open side downward?
E90 335i Auto, Cold Weather, & Sports Prem. Package, Navigation
Mods: JB4/MHD, ACF ST, Precision T/S 6062, AD-Eng Mounts, PrecisionRaceworks STG_3+LPFP,//HPF Exhaust Titanium Tips, Custom HighLow OCC, Precision RaceWorks Coils,RACE InterCooler, Custom Meth Kit, v8Bait(Justin)Tuning |
05-11-2015, 04:02 PM | #2 |
ex deus machina
124
Rep 968
I did on mine after having some lazy timing on #2 and sometimes on #4
the reason is because the OE Bosch plugs have shallow ground electrodes so it doesn't matter how they are installed, however on the NGK 5992, the ground electrode is deep and protruding, so it needs to face away from the fuel injector. I suspect that if it faces the injector directly you end with uneven flame front which causes lower timings on the cylinder compared to others
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK Gone: E92 335i N54 468rwtq |
05-12-2015, 12:04 AM | #3 |
Rep 2,842
I just tried the NGK's and they idle really rough on cold startup.
After about 30 seconds they smooth out and once the car is warmed up they feel as smooth as the Bosch OEM's. I gapped them to 0.22" but wonder if that is too tight of a gap and contributing to the rough idle? |
05-12-2015, 11:00 AM | #5 |
///Member
50
Rep 327
Checkered sent you a PM.
Think Checkered is right with how they sit in head.i without indexing I tried all ngk plugs and the open side of plug sits anywhere between12-4, think they should sit the opposite.im not 100% sure
05-12-2015, 11:37 AM | #6 | |
Rep 2,842
So mine being set to 0.20in might be causing the poor cold start. Funny because PTF's website actually recommended this gap in the first place. Anyone else gap their NGK's at .027? |
05-12-2015, 11:43 AM | #7 | |
Rep 6,478
Now they're gapped to .019, which is fine once the motor has some heat in it. But cold starts w/ E85 when it's below 50F is rather comical. Sometimes the car will cut out alltogether if it's at/around freezing
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
05-12-2015, 12:31 PM | #8 | ||
ex deus machina
124
Rep 968
1. I marked the ground electrode with a sharpie on the white porcelain, 2. First hand tighten each plug, for a full seat the plug needs exactly half a turn (180 degrees) for proper torque, 3. knowing #2, if the ground is facing away from the injection (after hand tightening) and I would do half a turn it will improperly seat, so I try different plugs until the ground is facing the injector, and then tighten fully so it faces away. 4. a. If no plug works in a particular cylinder, you can slightly over tighten by going 200-220 degrees 4. b. What I did with a local friend is remove one of the washer from an old plug and double up on the washers.
05-12-2015, 01:16 PM | #9 | |
Rep 2,084
2013 135is DCT Carbon Black Metallic |
