**Yawn, cylinder 5 misfire.**
05-12-2015, 08:48 AM | #1 |
Rep 133
Already replaced plugs and coils about 2-3K miles ago. Went through my own diagnostics procedure and swapped coils around to see if problem followed and it stayed on cylinder 5. I don't think the car has ever had injectors replaced so I am thinking it may be one of those.
My car is an 09 E90 N54 build and was wondering if there are any recalls or notifications from BMWNA regarding replacement. My car has no warranty given it has 63K on the clock.
2009 BMW 335i - Sport Package - Louisville, KY |
05-12-2015, 08:52 AM | #2 |
3442
Rep 79,211
Pull spark plug 5 and see if it's fouled with fuel. If you a have a rough start up when the car is cold in the morning it's usually injector related.
05-12-2015, 04:48 PM | #4 |
Rep 2,049
Pull the plug out when it's cold and smell for fuel. It won't rule out injectors completely but it's a good start.
I had a misfire due to a faulty injector but normal crank time. What's the last 2 digits of the injectors? I think -12 is the current.
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV, VRSF 5in FMIC, BMS Downpipes COBB e30 |
05-13-2015, 07:23 AM | #5 | |
Rep 133
I can drive around town and on the interstate just fine (minor jolts and bumps for the misfire) unless I really hit the gas and that's when it shutters like crazy. Also, it doesn't throw a code or the SES light unless I floor it.
05-13-2015, 07:31 AM | #6 |
Rep 663
I just had 5 out of 6 injectors replaced due to recall yesterday. Of course I'm in Europe and things are a bit different over here (we don't have any options on the HPFP like you guys do), so I don't know if the same recall will be valid for you, but my car is an 08 with 35k miles well out of warranty. They did it completely on their own, I didn't even know until they called me to tell me it was ready and said they also changed all but one of the injectors (although I am fairly confident one of them was leaking)...I was happy to say the least, as I also didn't have to pay for the spark plug install I had asked for (since they had to come out for the injectors).
08 E92 335xi 6AT, Sapphire Black Metallic
Modlist: 19x8.5+32/19x9.5+35 BBS CH-R Black, Michelin PSS 225/35/19 - 255/30/19, rolled rear fenders | KW v3 coilovers | Akrapovic exhaust Keep it on the black stuff shiny side up! |
05-13-2015, 07:55 AM | #7 | ||
Rep 2,049
Get the tool. Swap plug if coil and see if it follows. Then move on to injectors. It sounds to me like a plug.
'10 e92 N54
05-13-2015, 09:24 AM | #8 |
4517
Rep 1,862
Drives: powered by bootmod3
Unless you have cold start issues in the morning it is highly unlikely its an injector issue. If after plugs and coils you're still misfiring you can try replacing the injector in that cylinder blindly (make sure you get it recoded too). If you're lucky it'll be resolved. Otherwise next thing I'd do is do a compression and leak down tests. All of this applies if you're a 6AT car. For manuals there is another cause to them and it relates to the OEM dual mass flywheel which with time can start to vibrate and cause false misfires. The fix there is to swap it either for another OEM dual mass flywheel (if the car is below 500wtq levels) or go with a single mass flywheel. This doesn't apply to automatics obviously.
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
05-13-2015, 09:57 AM | #9 | |
Rep 133
05-13-2015, 10:33 AM | #11 |
4517
Rep 1,862
I thought you had the plugs replaced. What plugs are you running currently?
05-13-2015, 10:42 AM | #12 |
Rep 133
I did have plugs replaced by a dealer here in Ky but this was prior to me learning how to DIY on this type of stuff. I am running the bosch plugs that I ordered from ECS or another website making me think even more now it could be a faulty plug.
05-13-2015, 11:23 AM | #14 |
Rep 133
Yes was tuned - just Cobb stage 1 aggressive - I uninstalled it to see if that helped make a difference but no change.
05-13-2015, 02:03 PM | #15 | |
Rep 133
I am wondering if it is purely carbon buildup on my intake valves. I have never had it blasted nor do I even know if that has anything to do with the throttle jolts.
2009 BMW 335i - Sport Package - Louisville, KY Last edited by MK335i; 05-13-2015 at 02:29 PM.. |
05-13-2015, 05:28 PM | #16 | ||
Rep 2,049
I never heard of someone curing a misfire like you but enjoy it I guess
'10 e92 N54
05-14-2015, 07:31 AM | #17 | |
Rep 133
I did notice one of the codes I got it to throw yesterday was a low fuel misfire or something to that extent but I did not have low fuel.... hmmm
05-14-2015, 09:39 AM | #18 | |
3442
Rep 79,211
However it's not limited to those only, it can sometimes be gunked up intake valves, dirty/failing vanos solenoids. Last but not least it can sometimes be related to the low or high pressure fuel pumps. http://www.e90post.com/forums/showthread.php?t=631829 Intake valves should be cleaned every 35K miles. Vanos solenoid problems sometimes may throw a code as well as the potentially failing fuel pumps. How many miles are on the vehicle and are there any other codes? Those codes could be a big hint. |
05-14-2015, 10:40 AM | #19 | |
Rep 133
63000 miles on the car.
05-14-2015, 10:44 AM | #20 | |
3442
Rep 79,211
Once you resolve this, assuming it's not your intake valves gunked up, you should get those cleaned anyway. You'll likely gain gobs of throttle response, gas mileage and 10+HP. At the mileage you have they should have been cleaned almost twice now. |
05-14-2015, 12:58 PM | #21 | ||
Rep 2,049
'10 e92 N54
05-14-2015, 01:43 PM | #22 |
Rep 133
Haha I hope you are right.
