N54 335i Fuel Injector issues
05-14-2015, 01:52 PM | #1 |
Rep 52
Hello all,
I know there are numerous articles or posts regarding the known issue with 335i fuel injectors going faulty. But I couldn't find any posts about if taking the fuel injectors out and cleaning them and recoding them would fix it? Does anyone know if this is possible? Or would the fuel injectors need replaced once faulty? (sorry all I'm a newb) Also if anyone has an updated link of INPA software and would care to share, that would be great and much appreciated. I found some old posts, but they are from years ago, not sure if they still work. I will give it a go once I'm home today. Also if you could link any ODBII USB cables please. I know there is a recall on them, but unfortunately the recall is "VIN specific". I tried calling my local BMW dealer and BMW North America, and they all said the same thing, my VIN doesn't fall within the recall. I have a 2007 335i coupe, the car had its HPFP replaced by the previous owner. I changed my coil pack and spark plugs and noticed that fixed nothing. Fuel Injectors are about $230-250 each I believe from what I could find. Sorry for the long entry all. Any help will be great. THANKS!!! link any recommended: OBDII USB Cables that were successful for you. I heard the cheap china ones would not work with INPA software. |
05-14-2015, 02:27 PM | #2 |
M3 Haha
11
Rep 43
Drives: 07 E90 335i
Cleaning the injectors in a DI system is hit-or-miss; they're not as easy to clean as injectors in a carb engine. If you're in need of some new injectors, check out the FJ1050 injectors by Intermotor - they're original (!!!) BMW injectors and can be had for $130 bucks a piece at RockAuto. I replaced a bank of injectors with three of those and they've been running flawlessly for 3 months now.
05-14-2015, 06:56 PM | #3 | |
Rep 52
here at: http://www.pelicanparts.com/BMW/tech...eplacement.htm |
05-15-2015, 03:20 AM | #4 | |
M3 Haha
11
Rep 43
Drives: 07 E90 335i
05-15-2015, 07:19 AM | #7 |
Rep 3,969
I had two sets of injectors rebuilt, six of them ended up being "acceptable", then after running them for a few days I had three that were leaking. Altogether I spent around 500 to end up with three old injectors that work, but may fail any time. A new Intermotor set of six is a little less than 800. You do the math.
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
05-15-2015, 07:33 AM | #8 |
Rep 718
Yep, Bentley manual says 10 uses for the nuts and fuel line.
05-15-2015, 03:24 PM | #9 | |
Rep 52
kaigoss69 ahh yeah, i'll definitely have to check out the Intermotor set. Have you all replaced yours with the intermotor set? Are they recommended or of great quality? Digitalism MiniXP Awesome!!! Thanks, I'm glad its not a one and done! Don't want to have to buy another set of things to fix the fuel injectors. |
05-15-2015, 03:37 PM | #10 |
Rep 52
Also does anyone i see 2 sites, which one is the correct intermotor site, I never been on there before? Not seeing a price for the fuel injectors, just product information.
http://www.intermotor.co.uk/smpeurope/intermotor.asp and http://www.intermotorimport.com/page...motorhome.html |
05-16-2015, 12:35 AM | #11 | |
M3 Haha
11
Rep 43
Drives: 07 E90 335i
05-16-2015, 10:58 AM | #12 | |
Rep 52
05-16-2015, 04:03 PM | #13 | |
M3 Haha
11
Rep 43
Drives: 07 E90 335i
you will have to source the injector seals and decouplers from another site, though. |
05-16-2015, 08:17 PM | #14 |
Rep 36
If they are new injectors you shouldn't need seals. That is what the metal cap is for over the tips. Decouplers will be needed though.
05-16-2015, 09:36 PM | #15 |
Rep 2,049
The ones from rockauto are original believe it or not. Even tho it's some generic brand, they actually come from the same factory as the BMW ones.
130 bucks is a steal!!! I think the new injectors that end with -12 are up to date and don't crap out as easily.
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV, VRSF 5in FMIC, BMS Downpipes COBB e30 |
05-19-2015, 11:49 AM | #16 | |
Rep 52
Thanks again all. |
05-19-2015, 11:52 AM | #17 |
Rep 52
wow just checked the rock auto site again with the link provided and they are at $111.79 a piece. thats a good price, will have to get these soon but will want to test out the INDA software once i find it to make sure i can at least code it.
05-19-2015, 03:15 PM | #18 |
Rep 4,392
Fuel Injection Issues, rough starts, idle issues ? Start with these first
On empty tank pour this in before fill up with "pump gas" http://www.techronworks.com/en-US/products.html On next empty tank pour this in before fill up with "pump gas" https://gumout.com/fuel-additives/re...ystem-cleaner/ Use top tier gas / gas stations http://www.toptiergas.com/retailers.html I have used these combinations and it worked for me personally and others I have recommended to who's cars I have tuned before going to buy new injectors, HPFP, or LPFP etc |
05-20-2015, 03:22 PM | #19 | |
Rep 52
WOW this is awesome! thanks you, i will definitely try this first. Thank you again for providing me with this! Hope this works cause its starting to get a bit rougher as days go on. //EDIT// Just ordered 2 sets of these each and will try these out!!! and will be pumping shell V power for these! Thanks again Last edited by VarCity_E92; 05-20-2015 at 03:39 PM.. |
05-20-2015, 03:27 PM | #20 | |
3442
Rep 79,211
05-20-2015, 06:23 PM | #21 |
Rep 52
05-20-2015, 09:38 PM | #22 |
Supreme Galactic Commander (one galaxy over...)
675
Rep 1,778
11's are just older from what I understand. I think an 11 for $110 is still a great deal. I am close to pulling the trigger on the rock auto deal. The only "faulty" ones I know of were less than 09 and are in a BMW service bulletin. *IF* you have misfire issues you can get faulty injectors replaced by BMW under that TSB.
Best,
Andy '12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune |
