V2, Octane tune question
02-08-2008, 09:46 PM | #1 |
Rep 1,948
Been reading through but not getting the answers i'm looking for! I have V2 on 90% settings. The car is making boost around 14.4 - 14.9psi logged. This is all on 94 Octane. Now for my question, if I put in some 109 Octane fuel, do i adjust the torque settings again as I remember Shiv mentioning running higher torque settings with race fuel or does procede and the ecu adjust for me?
BTW, all i have is just V2. Otherwise the car is stock. |
02-08-2008, 10:00 PM | #2 | |
Uhcoug2011
37
Rep 757
Sparkling Graphite E90 / JUICEBOX 3 / BMS DUAL CONE FILTERS
02-08-2008, 10:05 PM | #3 |
Rep 115
I was told that the 90% tq setting is the default for V2 for 91 octane in CA. and that since we have 93 octane in FL. I should be able to bump it up to 92% with no problem.
In my post showing my V2-only dyno...Shiv responded and mentioned 94%...I am trying to get clarification if I can go to 94% with no problem... but I would imagine that if you are getting 94 octane you should definitely be able to go to 92% at least.... anyone? |
02-08-2008, 10:12 PM | #4 | |
Uhcoug2011
37
Rep 757
02-08-2008, 10:17 PM | #5 | |
Rep 6,608
One percent point above octane.... 92% for 91, 94% for 93, etc... But this is all depending on what the boost logs say. If at any time your boost is higher then 15psi then you need to lower the settings. G/L
I install all tunes, intakes, o2 simms, and most cosmetic mods. PM me for a quote. |
02-08-2008, 10:33 PM | #6 | |
Rep 217
Now, once higher than 93 octane is involved(race fuel/100+ octane), then I assume that the max boost limit is not so much of a factor. Correct me if I'm wrong guys, but this is the way I understood it. Plus I want to adjust my settings as well and could use some clarification. |
02-08-2008, 10:40 PM | #7 | |
Rep 6,608
02-08-2008, 10:43 PM | #8 | |
Rep 1,948
The 1 below octane rule doesn't apply unless someone is going to be at 108% using VP109 |
02-08-2008, 10:47 PM | #9 |
Rep 1,948
The question is what do I adjust the settings to? I mean, i'm already running boost of 14.8 - 14.9 psi. I doubt i can raise the settings more as I would be over 15psi boost for sure.
02-08-2008, 10:58 PM | #10 | |
Rep 217
02-09-2008, 12:09 AM | #11 |
Rep 10,587
if you are boosting that high I would leave it alone....also install a good boost gauge to be sure.
02-09-2008, 01:20 AM | #12 | |
Rep 1,310
I was running low 14.x psi until I started screwing around with the torque settings. I run a 50-50 mix of 91/100oct only, from the day after I installed V1.47. Upping the user torque setting caused my boost to decrease, even after almost 100 miles of daily driving with a dozen or so trips to redline (no limps). I'm back to 91% and seems to be nearly back to normal. My Forge DVs just shipped... |
02-09-2008, 08:59 AM | #14 |
Rep 571
After reading the Shiv Report on engine load I'm not really sure that the max 15PSI setting means a whole lot. I think it is more like a starting point because the TMAP takes over and monitors engine load base on density of air then adjusts the PSI accordingly. I think we need more input from Shiv that provides details on how to read the drop off PSI data rather than the max psi data. So if we are running 91 octane then the psi should be no higher than 11PSI and 94 octane should be no higher than 12.5PSI. Shiv have been very adement about the peak PSI doen't really matter as much as engine load. Perhaps he uses peak as a CYA. Everyone is hung up on the Max or Peak PSI and I'm not sure we should be concerned with this as much as the rest of the pressure data. Just say'n.
02-09-2008, 09:23 AM | #15 | |
ocasionally in crisis
52
Rep 2,358
If your car isn't scary - it's just not fast enough !
RPI IC / UR catless DPs / JB3 2.0 beta / UR CAI / Quaife LSD / Snow Methanol Injection / VK oil cooler upgrade / Forge DVs / M3 rear sway / Riss catch can / Paddle shifting 6AT / M Sport steering wheel / Logic 7 / Dunlop Direzza Z1 255/235 / |
02-09-2008, 10:15 AM | #16 | |
Rep 496
Manny : 2008 335xi sedan : SG, Terra, Alum, 6mt, SPP, PP, 162s Mods; Procede V4 | Remus Quads | UR catless dps | H&R coilovers | Modified CDV | Injen Intake | Spearco IC | Forge DVs | Defi Boost Gauge w/controller | Vorsteiner CF Hood + Front Lip | OEM M-tech Body kit | Hamann eyelids | Predator Ice Angels | 19" Volk Progressive Me's | Rotora BBK | 18" Rota Torques w/Blizzaks |
02-09-2008, 10:41 AM | #17 |
Rep 571
Wow! That looks nice. What is the % set at. Also, since we are talking Engine Load I think it would be nice to know your Ambient Temperature. Shiv explained that the ECU calculates based on air Density and the TMAP is temperature compensated. Perhaps the Ambient Temp is not a crucial?
02-09-2008, 10:50 AM | #18 |
Rep 4,481
My engine load numbers are as high as yours. Why should this be a problem ?
02-09-2008, 12:03 PM | #19 |
Rep 496
I was just looking at others datalogs and saw a peak of 80 on some...mine goes above 80 and it doesnt show it on the chart...i thought engine load is what we have to be careful about...if the procede software scales it the highest to 80...then why does mine go way above it...its completely off the scale...if others are like this then im not worried...i have the torque setting to 90%, and im already getting 14.8. Do you guys think if i up it a percent or 2 the boost taper would get better or worse?
02-09-2008, 06:12 PM | #20 |
Rep 1,948
I'm still trying to understand what is involved when increasing the torque values. I mean, I understand that timing, fuel boost etc are adjusted. What else is being adjusted? And my original question, do we have to make adjustments to compensate for the higher octane, (104 or 109)? Are there other perimeters that we can adjust to get a custom tune.
02-09-2008, 06:16 PM | #21 | |
Rep 496
02-09-2008, 06:28 PM | #22 | |
Rep 1,948
