E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > VRSF FMIC install issues on 2011 BMW 335is
Reply
      06-04-2015, 06:19 PM   #1
Stillswingin26
Stillswingin26's Avatar
Drives: 2012 135i
Was installing my VRSF FMIC today when I ran into an issue connecting IC to boost pipes.
First on passenger side am I supposed to to remove the OEM pipe and use the provided tube by VRSF. If so how do you remove it the clamp holding it on looks like it's unremovable..
Second, for drivers side the boost pipe connecting CP to IC is one piece, looks like the only way to use VRSF provided tube I'd have to actually cut this pipe, which I do not want to do..
First pic is reference from passenger side
Second pic is drivers side
      06-04-2015, 06:28 PM   #2
bryce-o
Drives: 2013 BMW 335is 6mt
Use a dremel tool to cut the band on the passenger side. The drivers side needs the j pipe that vrsf charges $45 extra for. You remove the whole lower charge pipe, and connect the j pipe to the upper charge pipe that goes to the throttle body
      06-04-2015, 07:04 PM   #3
Stillswingin26
Drives: 2012 135i
$45 more, that's a bunch of crap why isn't it included if they know I need it?
      06-04-2015, 07:10 PM   #4
bryce-o
If I remember correctly, when you order it, there's an option for 2009+ that require the extra pipe. 2007-early 2009 build dates don't require the pipe
      06-04-2015, 07:36 PM   #5
Stillswingin26
Drives: 2012 135i
Yea, found out I did order it (looked at my invoice) but wasn't sent to me, trying to resolve this now
As far as passenger side, is there a simple way of removing that "one time" clamp?
      06-04-2015, 07:58 PM   #6
Miller335
Drives: 2007 E92
Dremel with small cutting wheel.
Just go slow, you want to avoid hitting the pipe of course.
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
      06-04-2015, 10:54 PM   #7
e92_boost
e92_boost's Avatar
224
Drives: Smart Car
If you ordered it PM Tiago! Tiago@VRSF
ESS G1 e90
- BBS E88
      06-05-2015, 12:34 AM   #8
gsr1416
Drives: Space Gray 335i E93
2011 BMW 135i  [0.00]
Passenger side can be removed by using flat head screwdriver and popping clamp no need to mess with cutting it off.
      06-05-2015, 12:49 AM   #9
musc
musc's Avatar
Drives: Audi TTRS, 335is
2011 BMW 335is  [10.00]
I cut mine with a dremel but you can easily pop it loose with a flathead screw driver as mentioned above.
      06-05-2015, 01:10 PM   #10
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
You need the lower charge pipe, it's an option when purchasing the intercooler and it's clearly listed
Reply
e90post
