help, front deiveshaft, rear universal joint all busted
06-07-2015, 02:03 AM | #1 |
Rep 776
I installed my downpipes today on my 07 335xi and noticed the front driveshaft universal joints were messed up pretty bad. Explains the massive clunking i was getting reverse to forward or vice versa, and maybe the little sputter i get from cruising speed to acceleration.
Are the joints replaceable or do i have to replace the whole shaft? |
06-07-2015, 02:30 AM | #2 |
Rep 2,872
Check ECSTuning, I'm not familiar at all with that issue, but I know you're not the first person I've seen have issues Xi related with higher power.
06-07-2015, 10:04 AM | #4 |
Head Fry Cook at McBurgertown
507
Rep 1,005
Front: $100 each new/$50 each remanned
http://www.partsgeek.com/mmparts/axle/bmw/335xi.html Rear: $330-ish each new: http://www.foreignautopartscatalog.c...?currentpage=2 https://www.fcpeuro.com/BMW-parts/33...35&m=20&page=1 |
feuer4277.00 |
06-07-2015, 10:59 AM | #5 | |
Rep 776
06-07-2015, 02:10 PM | #6 |
507
Rep 1,005
In that case:
$312 + tax complete new: http://m.autozone.com/autozone-mobil...?showymme=true BMW sells the "U joints" by themselves; although it may not be what you're after: http://parts.bmwofbridgewater.com/p/...wd=&origin=pla When I look at the part diagram, I'm not sure it's exactly what you're looking for though as they seem to be calling something else a universal joint and it doesn't look like what's traditionally considered a universal joint. If that's the case the drive shaft above should give you the ability to have servicable U joints moving forward. Last edited by terryd5150; 06-07-2015 at 02:36 PM.. |
feuer4277.00 |
10-05-2017, 07:53 PM | #8 |
Rep 776
Lol. Old thread revival.
Just busted that same shaft on the highway. Wow. What a noise. Can i actually pull it out and go just rwd? Won't the splines come out and dump my oil? Last edited by fredcase; 10-05-2017 at 09:28 PM.. |
10-06-2017, 07:35 AM | #9 |
Rep 538
Yes you can, make sure to unplug the transfer case actuator tho. I pulled mine to figure out if it wa the front driveshaft or not and didn't notice much difference. Ended up being my axles but I put in a new/used front shaft. I have to other one of you want it we could work something out. Are you lowered?
10-08-2017, 11:18 AM | #13 |
Rep 538
10-11-2017, 09:12 AM | #14 |
Rep 776
So, at the time of the incident i noticed some leakage under the car, i thought it was air conditioning condensation.
Now I've been driving it a few days, i found a little spot of oil under the car. Very clean, clear, light oil. Front diff leaking? What you all think? |
