6HP19/21 Transmission HELP~
06-08-2015, 09:03 PM | #1 |
Rep 45
Hello ,
I recently changed the transmission pan, mechatronic sleeve, and fluid, but I now have run into a couple problem and wondering if you guys can help me with them. I have a 2007 BMW 335i Coupe (JB4, DP, DCI, Exhaust), after driving for 10-15 mins after the fluid and pan change a lot of error lights came on (amber brake lights, DSC, amber transmission warning with exclamation mark). With the drive, the transmission seems to be stuck in gear 2 or 3 and would not shift. Sometimes the transmission would slip and sometimes transmission not get into gear and feel like a stall with no power. The next day, cold start there is no errors at all. Car drives smooth, all gears working and no slip whatsoever. But again after 10-15 mins of driving all the errors came back, and same scenario with the transmission where it is put into transmission limp mode with slips and stalls. I tried several cold start within the next few days and it is the same scenario after 10-15 mins of driving. I did some search online and checked the voltage with car engine on and off and all seems to be normal. So I don't think its the alternator or the battery. I read the code with JB4 and my mechanic read the error codes and got the following CDAD - Wheel Torque Request CD87 - Powertrain CAN communication error CD99 - Torque request EGS CD9D - Gearbox data CD9E - Gearbox data 2 The mechanic tried to clear all the codes and it would just come back. But this time, I started to see amber ABS light, the ABS light and DSC would go on and off, but the amber brake and amber transmission warning with exclamation mark always remains. I thought this extremely strange, because on cold start everything is fine. I don't understand why it only happens after 10-15 mins of driving. Any help would be greatly appreciated. Thank you |
06-08-2015, 09:21 PM | #2 |
Rep 1,465
Drives: 2009 BMW 335xi
Low fluid?
06-09-2015, 11:26 AM | #4 |
Rep 1,465
Well then the only other thing that changed was the mechatronics sleeve. There is probably a problem with the install. I know it has to go in a particular way and it can be hard to get the connector back on correctly.
06-11-2015, 01:10 AM | #6 | |
Rep 45
no problems at all, just slight leakage from the pan, but no transmission problems or slipping issues |
06-12-2015, 06:44 AM | #7 |
Rep 5,463
errors would indicate a communications issue with the trans, so going to go with Mechatronics connection also, either loose or a damaged pin.
Taking 15 minutes may mean that a little heat builds up and things move and change size a little and it is enough for the connector to loose connection (or could just be bumps in the road causing it to loose connection - sounds like it just needs to be a little tighter).
2025 X5 Msport
