Help!
06-20-2015, 10:57 AM | #1 |
Rep 52
Help!
I was driving yesterday on Lake Shore Drive and out of nowhere saw engine malfunction light and the car completely died. Luckily I was able to roll enough to the nearest exit and not be stuck on the highway.
the car was reading check battery terminal connection but the battery seemed to be working perfectly i connected the jb4 to my laptop this morning and saw code 3100 low boost mode engaged I really don't know where to start. Thoughts? Mods I have jb4 downpipe meth dci |
06-20-2015, 12:47 PM | #6 |
Rep 537
06-20-2015, 12:54 PM | #7 |
Rep 52
3100 low boost mode engaged -- CEL displayed
2ACC DME digital motor electronics main relay, switch delay 2A9E Camshaft sensor inlet, synchronization 2FBE Fuel pressure after motor stop 2CEF Throttle valve actuater, activation 0000 Unknown Fault 0000 Unknown Fault 2D09 Drosselklappe 2DEB Power management, vehicle wiring system control I finally got it to start but it definitely was not running right. shaking, revs going up and down. Sounded real bad |
06-20-2015, 01:15 PM | #8 |
Rep 152
Check your battery voltage.
Then clear codes and adaption with the car off, only do this if your voltage is at least 13 volts. If your battery voltage is less than 13 your battery may be bad. Bad batteries will cause our cars to act in strange ways. |
06-20-2015, 07:09 PM | #13 |
Rep 52
thanks guys. Going to head to my part shop Monday and will let you guys know. I'm thinking of just getting a bosch battery for around $120 and then I know a guy to reprogram it.
06-20-2015, 09:23 PM | #14 |
Rep 31
Careful unplugging the battery. A tech unknowingly broke the connector to the battery safety terminal and it was a royal pain to diagnose because it still appeared to connect. Don't pull too hard.
2009 335xi Le Mans Blue; JB4 - Map 5; flashed, VSRF DPs, VSRF Intercooler, transmission flash, VSRF chargepipe, LED interior, Angel Eyes, Glossy Black Grill, spolier, Rear Fog Light Mod, backup camera mod, 2020 Nav. Maps;
06-20-2015, 10:24 PM | #15 |
BimmerPost Supporting Vendor
24492
Rep 191,493
I would start with the battery.
06-23-2015, 08:09 PM | #18 |
Rep 52
new battery and reset adaptations. Car started but very rough once again. RPMs going up and down no power shaking and throwing the same codes pretty much.
I believe that you reset the adaptations by going to 1 on the speedo and 7 on the rpm right? |
06-23-2015, 08:30 PM | #19 |
Rep 335
I'm a Cobb guy so I could definitely be wrong, but IIRC resetting adaptations with JB4 doesn't clear codes does it? You need to clear those codes too.
06-24-2015, 02:42 AM | #22 |
Rep 537
check your vanos solenoids and maybe the vanos itself...i had similar idle issues and am still diagnosing it
