E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Turbo Diverter Valve Popped out
Reply
      06-26-2015, 02:41 PM   #1
therealphil
Drives: 2007 335i
Hi All,
Was passing on the highway last weekend when I heard a pop. Looked under the hood to see this:
I just pushed it back into place and it seemed to snap in securely. Haven't had it happen again. I am wondering if anyone has run into this and if it means the seal might not be as tight as it should be.
I was thinking it might be that the shop that did my walnut blasting left it loose.
Any thoughts would be appreciated.
NVM:
found a few threads:
http://www.e90post.com/forums/showth...diverter+valve
Last edited by therealphil; 06-26-2015 at 02:47 PM.. Reason: found a solution after actually searching.
      06-26-2015, 04:49 PM   #2
tampaturbom3
Drives: 2013 BMW M6 Coupe
Yep. When I did my walnut blast,I thought I had secured those but one popped off under boost like yours. I re locked it and it hasn't done it again.
Tommy
2013 M6 Coupe- Tanzanite blue
      06-26-2015, 06:33 PM   #3
gabylonfive
gabylonfive's Avatar
Drives: 04 M3, 05 Elise
i bet the twist-lock wasn't rotated and secured properly. If it was and it still came off, it would be broken at the fitting.
Reply
e90post
