Tackling this misfire. I'm not a noob lol.. Please give me some input
06-27-2015, 03:55 PM | #1 |
Boosty
55
Rep 325
Yes I Posted on n54tech... lolll
The other day driving with some e85 in the tank map7 and my methanol kit barely spraying I did a WOT throttle pull. Well a couple of them lol. I am in 3rd and get a misfire and the car sounds like a truck. It was happening at the track recently also. But I restart the car and it usually goes away. This time it did NOT go away upon restarting the car... I was getting misfires on 2 and 5.. sometimes 6.. The car was running really really bad. I looked at the plugs and checked the gaps which are gapped at .022 (the one step colder NGK's) picture attached. I replaced all new coils today and now I'm getting a cylinder 6 misfire only. and the car isn't running as bad. I'm guessing because only one cylinder is misfiring now. I moved the coil packs around and the misfire did not follow... What else could be my problem thats causing this misfire? I also washed the engine bay but the car started and ran fine after that for a good 40 minutes. and I used a leaf blower to blow all the water out. The plugs were dry. Not wet. Could it still be an injector? The only code I am getting is 29D2 Misfirings Cylinder 6.
'08 335i AT Alpina Flash~Rob Beck Turbos~Full kittyless exhaust~DCI~5" Intercooler~Chargepipe BOV~BMS meth kit
06-27-2015, 04:09 PM | #2 |
Rep 3,552
since all coils are new, swap the plugs. if not then its injectors.
edit-i would change those plugs if i were you even if they "work"
12.0 @ 117 |
06-27-2015, 04:11 PM | #3 |
Boosty
55
Rep 325
Can I switch the injectors around? Put cylinder 1 in cylinder 6? To confirm it is the injector?
06-27-2015, 04:29 PM | #4 | |
Rep 522
I myself never tried this method as i have also read that the little rubber on injectors goes bad upon removal... Conflicting info huh... When i had cyl 5 issues i just changed that whole injector for a new one after trying all the other less expensive options |
06-27-2015, 04:30 PM | #5 |
Rep 2,872
06-27-2015, 05:02 PM | #6 |
Boosty
55
Rep 325
I just had a walnut blast done a couple 1000 miles ago. I took the intake manifold off and they are still clean.
It's a constant misfire. It doesn't go away. Ughbbb
06-27-2015, 08:39 PM | #7 |
Rep 2,872
Sounds injector related.
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
06-27-2015, 08:41 PM | #8 |
Boosty
55
Rep 325
So since I have the old index number I have to upgrade all the injectors ? (
Is this covered under any type of recall?
06-29-2015, 02:19 PM | #9 |
Rep 305
06-29-2015, 04:35 PM | #11 |
Boosty
55
Rep 325
Plugs have about 6,000 miles on them
06-29-2015, 06:35 PM | #12 | |
Rep 719
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
06-29-2015, 06:47 PM | #13 |
Boosty
55
Rep 325
Okay thanks for the reply. I will try that
