Sensor under gasket ?
06-28-2015, 11:33 AM | #1 |
Rep 149
Drives: 2011 328i Xdrive
Ok guys, I just did my cover gasket replacement. At the end the mechanic said there is some sort of oil sensor that is leaking and needs to be replaced. The only way to access this sensor is by removing the cover gasket. The sensor cost $600 and he said I probably have 2 months before it goes. I want to try to find the sensor somewhere online to potentially see if I can get it for cheaper. Does anyone know a place to look and the exact name of this sensor? Cheers
07-05-2015, 09:36 AM | #2 |
Rep 313
is he talking maybe about the eccentric shaft sensor seal? thats the circle plug with the wire coder to front of the car on the valve cover.
Mine is seeping a little too and was wondering if it can be changed without removing the valve cover as my VCG is fine. One shop told me that in order for that eccentric shaft sensor seal to be removed, the valve cover would have to be removed, while others say it can just be pryed off. Not sure who is correct as the valve cover is made of plastic |
07-11-2015, 11:38 PM | #3 | |
Rep 149
07-12-2015, 09:51 AM | #4 | |
Rep 2,835
07-12-2015, 02:03 PM | #5 | ||
Rep 149
07-12-2015, 04:05 PM | #6 |
Rep 2,835
