06-29-2015, 03:03 PM | #1 |
Rep 308
are these spacers ok?
i used these spacers for my previous car. 5x114.3 i think they are 5mm..
It suppose to be universal but i don't know which sizes fit. Is it fine to use these spacers without extended bolts or hubcentric ? and the bolt pattern is ok to use for 328i?
F30 328i sedan
06-29-2015, 08:22 PM | #2 |
Rep 713
I wouldn't want to use them unless they were hubcentric and had longer bolts for the additional 5mm. Even with properly fitted spacers, improperly installed can cause vibrations.
06-29-2015, 11:27 PM | #3 | |
Rep 308
Wouldn't the spacer self center because it'll be held in place by 5 bolts? i'm not really worried about the additional 5mm longer bolt because i heard that if you can turn the bolt ~5 turns by hand than bolt will not get loosened or dangerous. is the length of the hubcentric on rotor long enough for 5 mm spacer?
F30 328i sedan
