Replacing Injectors, question tho?
07-08-2015, 11:50 AM | #1 |
Maximus Decimus Meridius
1132
Rep 4,586
So my car is at the dealer right now undergoing a service diagnostic and they told me "you need to replace your injectors" which basically tells me that one or possibly two is bad and they just want to replace all of them.. Question is, if I find out that it is only one or two, can I just replace that one or two, or should I replace all of them, or even just 3 at a time..?? Also if I were to replace them can I have 3 on one index and 3 running a different index..?? Is this what the coding takes care of..??
Thanks!
F30 335i Melbourne Red Metallic M-Sport Package |
07-08-2015, 01:08 PM | #3 |
Rep 2,872
People have done just 1 injector many times, if it's coded in you should be OK. However BMW recommends replacing the entire bank, not just 1 injector.
07-08-2015, 02:33 PM | #4 |
Professional Monkey Trainer
65
Rep 423
Hit the nail on the head. If the injectors in that bank have an index lower than 10 and you're putting the new injectors in you're supposed to change a whole bank but some people say eff that and do 1 and no one has reported anything negative.
JB4 G5 ISO / ER Charge Pipe and Tial BOV / Wagner FMIC / CYBA Tips & Air Scoops / AFE DCI / BMW PE Exhaust Mod / M3 Rep Bumper / Dynavin E9x
07-08-2015, 02:49 PM | #5 |
BimECU
193
Rep 759
i had all pre 10 index injectors and replaced only one to index 12 in last november
running fine since then, boosted |
07-08-2015, 03:22 PM | #6 |
1132
Rep 4,586
Thanks for the great feedback guys.. I have a lot of financial responsibilities coming within the next week or so, my grandmother just got really ill and it's on my shoulders so if I can just do one for now that'd be awesome..
I appreciate it, hopefully some of those guys who've done this can chime in.. Now I just have to find out how to I identify the faulty injector, not sure if BMW will tell me this when I pick it up today... I assume it would be the darkest or cleanest spark plugs..??
07-08-2015, 03:43 PM | #7 |
3442
Rep 79,211
Just ask them which injector(s) are bad and tell them you are on a tight budget so you'd like to replace the minimum necessary to drive the car safely.
They typically want to replace at least 1 bank of 3. You can theoretically just replace 1 so as long as it's coded correctly. |
07-08-2015, 03:54 PM | #8 | |
1132
Rep 4,586
If I have -10 injectors, and I found a -10 for sale, would I still need to code it and all that..?? Thanks for ur input Jeff..!
07-08-2015, 04:34 PM | #10 | |
65
Rep 423
Best way to find out the leaky Bastard is start it up cold after it's been sitting for awhile. Let it idle like 5-10 seconds, then turn it off. Find the cleanest plug or the one that reeks the most of fuel and thats your B!&CH
07-08-2015, 04:40 PM | #11 |
BimmerPost Supporting Vendor
24492
Rep 191,490
They can replace one and code it. But when one injector fails, this is a sign that they are all on their way out. I would do at least a bank of 3 injectors.
07-08-2015, 05:47 PM | #12 |
Rep 2,049
Rock auto sells them for $110 a piece and they are original BMW although it's advertised as "generic" just FYI
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV, VRSF 5in FMIC, BMS Downpipes COBB e30 |
07-08-2015, 07:09 PM | #13 | |
1132
Rep 4,586
Also, can I reuse the little fuel line that is connected to the injector..??
F30 335i Melbourne Red Metallic M-Sport Package Last edited by BeastMode335i; 07-08-2015 at 07:14 PM.. |
07-08-2015, 09:07 PM | #14 | ||
Rep 2,049
'10 e92 N54
07-09-2015, 12:48 PM | #15 |
1132
Rep 4,586
Awesome, thanks brother.. I'm ordering them today, just ordered spark plugs as well.. A buddy of mine is letting me use his spark plug socket and also his K+DCAN cable so hopefully by next weekend I'm back in business..!! I found that DIY Fuel injector coding thread on here, wow what an amazing writeup..! The only issue I may have is that I have a Macbook Pro, and I'm running Windows via VMWARE and I didn't have success with INPA before on that same setup, but I assumed it was a faulty K+DCAN cable..
07-09-2015, 02:59 PM | #16 | |
Rep 2,049
'10 e92 N54
