Why didn't I think abt that??? (leaky injector)
07-10-2015, 01:16 PM | #1 |
Rep 1,909
I think this's an excellent idea to test for leaking injector(s), stole it from the web lol
Mods: 7" VRSF FMIC, Forge DVs, RB PCV, BMS Oil Cooler, VRSF DPs, MHD, JB4g5, OFT DIYs: Walnut blasting : Trans Oil at 45k, w Filter at 65k : Diff Oil Flush @ 45k : WP&TS @ 69k : Alternator @ 79k --- E70d Alphabet Soup del 44.4k : JR Stg2.25 tune : Buzzken Catted Exhaust : Trans fluid drain/ fill (3 Qrts), both Diffs fluids flushed Wheels: Style 95s on PSSs (Sold): AG 359s on S04s : 162s on Blizzaks : Rohana RF1 Matt black
07-10-2015, 01:32 PM | #3 | |
BimECU
193
Rep 759
07-10-2015, 01:34 PM | #4 |
Rep 1,909
I don't think they should ever leak without electric pulse, also all should leak in that case why just one
07-10-2015, 01:50 PM | #5 |
Rep 2,049
Or u can pull the plug and smell it as it sits overnight
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV, VRSF 5in FMIC, BMS Downpipes COBB e30 |
07-10-2015, 01:52 PM | #6 |
BimECU
193
Rep 759
other option is to disconnect all injectors, and then turn the starter,
if you listen carefully you can determine if the ignition is happening |
07-10-2015, 01:56 PM | #7 |
Rep 670
OK, I'll ask the dumb question. If you are cranking the engine, why wouldn't all injectors spray?
edit- or is just the fuel line connected and not the electrical connection?
2010 335i e90 Le Mans Blue/Chestnut Brown | M-Sport | 6MT
07-10-2015, 02:04 PM | #8 | |
BimECU
193
Rep 759
07-10-2015, 02:05 PM | #9 |
Rep 2,084
Fuel line is connected but not the electrical. So the video is showing the injector spaying fuel without any signal, hence leaking
2013 135is DCT Carbon Black Metallic |
07-10-2015, 03:26 PM | #10 |
Professional Monkey Trainer
65
Rep 423
This is genius, only it may be more difficult to pull all the injectors rather than the plugs.
JB4 G5 ISO / ER Charge Pipe and Tial BOV / Wagner FMIC / CYBA Tips & Air Scoops / AFE DCI / BMW PE Exhaust Mod / M3 Rep Bumper / Dynavin E9x
07-10-2015, 03:33 PM | #11 |
Rep 1,909
ooops sorry, but this is ingenious!!
07-10-2015, 03:34 PM | #12 |
Rep 1,909
still better than blindly replacing injectors, we've all done that right/?
07-10-2015, 04:59 PM | #13 |
65
Rep 423
Ooooo ya. When in doubt replace them all.....That's how you do it right?
07-10-2015, 11:31 PM | #14 |
Maximus Decimus Meridius
1132
Rep 4,586
dude this is awesome and has win written all over it.. well, because I just ordered 3 injectors and was going to "hope" i was replacing the right ones..!! This looks like a dead giveaway at what injectors will be faulty..! Thanks brother..!! :cheers:
So just unplug the electrical connectors, and push and hold the start button..??
F30 335i Melbourne Red Metallic M-Sport Package Last edited by BeastMode335i; 07-10-2015 at 11:48 PM.. |
07-12-2015, 09:24 AM | #16 |
4ut0strd4
47
Rep 223
Plus if you look closely it's pretty obvious that the one leaking has a much darker tip from build up as well just in case your injector may not be leaking too bad or at all during this test.
07-13-2015, 06:47 AM | #18 |
Rep 1,140
Drives: N54 135i 6MT
Check this out 7smurfs
07-13-2015, 09:11 AM | #19 |
3442
Rep 79,211
07-14-2015, 08:07 AM | #20 |
1132
Rep 4,586
Levanime would you mind letting me know the steps you did to get the injectors in that position? Also, did you reuse the decoupling elements from the injectors that were not replaced..??
F30 335i Melbourne Red Metallic M-Sport Package |
07-14-2015, 12:18 PM | #22 |
Rep 1,818
